The New Hypex Fusion Plate amps
Old 14th September 2019, 04:35 PM   #1571
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
ds23man - congratulations!
My AINO speaker has SEAS L26ROY sealed downfire 8cm from floor, and despite 25Hz distortion hitting 100% around 105dB, it sounds really nice and potent enough! Did you try the Grimm woofer box upside down?
Radikal aktivist AINOgradient speaker project
Old 14th September 2019, 05:17 PM   #1572
ds23man is offline ds23man  Netherlands
ds23man's Avatar
The Grimm sub is the design of Rob and i did not have anything to do with it.
Rob and I teamed up to design a digital MFB solution for the Fusion amp.
Old 15th September 2019, 01:59 AM   #1573
troystg is offline troystg  United States
troystg's Avatar
Is that solution available to mere mortals who don't drive Ferraris?
I use Mr. Erath's feedback(servo) system but I would like to try yours as his is 60's technology. It still sounds good(actually very good as a lot of the old gear does) but I did hear the Grimm system at the Munich audio show and was impressed.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 15th September 2019, 12:13 PM   #1574
ds23man's Avatar
Yes, it will be.
Old 16th September 2019, 07:21 AM   #1575
TimbreAudio is offline TimbreAudio  United Kingdom
Like.
Old 16th September 2019, 12:22 PM   #1576
Pepe is offline Pepe  Sweden
Can a single 2 way fusion plats amp (fa252 or fa502) be used as a stereo amp? It was possible with the older plats amps from hypex (sa2.100)
I’m only dependent on the digital inputs.
Old 16th September 2019, 12:47 PM   #1577
Fenalaar is offline Fenalaar  Norway
Iím only dependent on the digital inputs.
No, itís not possible.
You have to select either left, right or legt+right(mono) channel.
Johan-Kr
Old 16th September 2019, 05:34 PM   #1578
Johan-Kr
Thank you for clearing that out.
Old 16th September 2019, 07:25 PM   #1579
They can be bridged though, if you did want to set them up more as mono-blocks, still need two, put can spec a lower output and lower price variant, if that helps at all...
Old 17th September 2019, 11:12 AM   #1580
Leliks is offline Leliks
Yes, it will be.
Super cool. Any estimate on timeline? By end of the year?
The New Hypex Fusion Plate ampsHide this!Advertise here!
Hypex Plate Amps madtrapper Class D 1 14th March 2014 05:21 PM
Opinions wanted on using the Hypex 2.4 plate amps? SpinMonster Multi-Way 2 3rd April 2012 08:26 AM
Hypex plate amps chatziva Class D 3 29th July 2010 03:33 PM
HYPEX plate amps Glen1 Subwoofers 0 27th January 2006 02:22 AM
Copyright ©1999-2019 diyAudio
