The New Hypex Fusion Plate amps
Old 1st April 2019, 01:59 PM   #1321
Juhazi is online now Juhazi  Finland
Juhazi's Avatar
^Obviously you have a quite high crossover then. Subwoofers and their xo slopes are very difficult to measure indoors. You should also measure the main speakers and their highpass slope...
Other option is to abandon all measurements and only trust your ears. Whatever settings that sound good!
Radikal aktivist AINOgradient speaker project
Old 2nd April 2019, 01:27 AM   #1322
powerman is offline powerman  South Korea
I tested without the main speakers.
The xover was set to 50hz LR 4th order.
One of the possibility was the 3m sub located at middle of the right wall where the strongest room mode was.
Maybe I lower the volume to minus, and trying invert one sub for fine tuning.
Old 2nd April 2019, 06:38 AM   #1323
_henry_ is offline _henry_  Australia
Measure your room.
If you have dsp, use EQ to compensate or if you have more freedom for placement, play around with sub position.
Old 2nd April 2019, 10:06 AM   #1324
Originally Posted by _henry_ View Post
Measure your room.
Thanks for the advice!
I did the sub scrawled, and now set up my mic for measurement!
Old 9th April 2019, 10:11 AM   #1325
sadhill is offline sadhill  Switzerland
On a FA123, in HFD release 1.3, are the delays absolute, or relative to the previous channel for the 2 last channels ?
Thank you
Francois
Old 9th April 2019, 10:41 AM   #1326
Juhazi's Avatar
Absolute, as far as I noticed.
Old 9th April 2019, 10:45 AM   #1327
strange that it is not stated in the manual... it is of quite some importance
Old 9th April 2019, 11:01 AM   #1328
Sabbelbacke is offline Sabbelbacke  Germany
Indeed If it´s not present there, maybe hypex could put in in a revised version.
www.hornresp.net
Old 9th April 2019, 02:21 PM   #1329
ds23man is offline ds23man  Netherlands
ds23man's Avatar
Never seen an active crossover with relative delay.....
Old 9th April 2019, 03:11 PM   #1330
hm, you are actually right, didn´t really think when I was posting.. Maybe sadhill could clarify what he meant.
www.hornresp.net
The New Hypex Fusion Plate ampsHide this!Advertise here!
Hypex Plate Amps madtrapper Class D 1 14th March 2014 05:21 PM
Opinions wanted on using the Hypex 2.4 plate amps? SpinMonster Multi-Way 2 3rd April 2012 08:26 AM
Hypex plate amps chatziva Class D 3 29th July 2010 03:33 PM
HYPEX plate amps Glen1 Subwoofers 0 27th January 2006 02:22 AM
Copyright ©1999-2019 diyAudio
