The New Hypex Fusion Plate amps
Old 20th March 2019, 01:23 PM   #1301
denibeni is offline denibeni
Ok, it seem miniDSP didn't specified any signal-to-noise ratio for their plate amps, thats strange.
Hypex FA's have way over 100dB SNR even, if ADC is considered.
May i try to hook up my two speaker parallel to get 99dB sensitivity, but i don't think that the noise becomes much noticable than now with 93dB.
Old 20th March 2019, 02:44 PM   #1302
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Default custom plate amp
Looks like I'm on the way towards a custom plate amp for my company. It's just a simple two way with DSP. I'll put it into a new loudspeaker that I hope to develop. Hypex makes doing this extremely easy.
Old 23rd March 2019, 08:51 AM   #1303
Fenalaar is offline Fenalaar  Norway
I have the Hypex DLCP and also a MiniDSP OpenDRC DA8. The latter, Ive had for a few years. The DA8 is noticeably noisier than the DLCP, but on drivers with hifi-ish sensitivity (88-91dB/W), its not really bothersome. For compression drivers, it would be a problem, unless some analog signal damping is put between dsp and amp (or padding on the drivers).
The amp Im currently using, has a Hypex UcD-34MP module for mid and tweet section and UcD180 modules for the woofers. With only 15dB or so gain, hiss is not an issue anyways in normal drivers.
Johan-Kr
Old 23rd March 2019, 06:03 PM   #1304
pk is offline pk  Denmark
Default Fans on the FusionAmp 502?
Hi
I consider using the FusionAmp 502 for bass, but I am bit concerned about potential fan noise, so:
1. Does the fan work all the time or only when the modules are working hard?
2, when the fans are 'on', are they noisy?
Thanks!
Best regards
Peter
Old 23rd March 2019, 06:55 PM   #1305
djmaxx is offline djmaxx  Latvia
They not work all time.
And when turns on - not very noisy.
Old 23rd March 2019, 07:09 PM   #1306
Hi djmaxx,
Thanks a lot!
Best regards
Peter
Old 26th March 2019, 02:28 PM   #1307
sadhill is offline sadhill  Switzerland
concerning the FA123 and it's NC122MP amp to be used without the DSP :
- connector J6.7 warns of amp stop on DC offset detected. Does anyone know if a small DC offset of the source is allowed, or none ?
- on J4, is it really necessary to keep all the wires connected other than the input lines ? (assuming you don't need mute, clip indicator and temperature sensor, but will it work without that one ?). If it had been possible, I would have bought the OEM NCores...
At present time, I'm still using the DSP. concerning HFD, it is possible to copy a preset on another preset in the same file. But is there a way to do it to another file ? Looking at the XML settings file, it doesn't look so evident to copy part of it...
Old 26th March 2019, 11:59 PM   #1308
cowanaudio is offline cowanaudio  Australia
cowanaudio's Avatar
A small DC offset doesn't seem to upset the amplifier.
J4 - Inputs only required
Tie J6.9 to J6.3 through your power switch and you'll have an operating amplifier.
Don't Procrastinate....Just Do It!
Old 27th March 2019, 07:32 AM   #1309
nice.
Thank you !
Old 29th March 2019, 02:30 PM   #1310
mlee is offline mlee  Canada
Hi All,
Thinking of picking up a FA253. Can any one comment on the low volume presentation of the amp when using the XLR inputs?
Thanks!
Think before you speaker!
https://www.diyaudio.com/forums/full...bac25-4-a.html
The New Hypex Fusion Plate ampsHide this!Advertise here!
Hypex Plate Amps madtrapper Class D 1 14th March 2014 05:21 PM
Opinions wanted on using the Hypex 2.4 plate amps? SpinMonster Multi-Way 2 3rd April 2012 08:26 AM
Hypex plate amps chatziva Class D 3 29th July 2010 03:33 PM
HYPEX plate amps Glen1 Subwoofers 0 27th January 2006 02:22 AM
Copyright ©1999-2019 diyAudio
