The New Hypex Fusion Plate amps
Old 7th September 2018, 07:09 AM   #1001
newuserhify is offline newuserhify  Denmark
Originally Posted by paalj View Post
Had a look at the Marantz SR7012. I can't fint other than subwoofer analog out in the "pre out" section? maybe the picture I am looking at is wrong....
Well, i am a noob 😊. There is onley analog sub out
Old 7th September 2018, 07:12 AM   #1002
Morten,
First make the settings as below. (this is for an other fusion amp, but should work)
Please make sure you set the correct input at the preset settings. Use Autodetect if you us multiple inputs.
Old 8th September 2018, 04:06 PM   #1003
Mortenke is offline Mortenke
@DannerD3H Hi, I use the 123 for 7" scanspeak 18W and 1" scanspeak alu dome. They're easily up to the job. I changed from 400w plate amps (ucd), and the Fusion is classes better in both low level detail, perspective/3 dimensionality and basis control + definition. I'd like to get going om mini DSP opendrc Acourate room correction as my room needs it - but even without, this is way up there. With a solidly built 2 way scanspeak monitor and Hypex Fusion you have a mighty system at hand.
Old 9th September 2018, 02:22 PM   #1004
Can fusion amps decode MQA as ie. Tidal Masters?
Old 9th September 2018, 04:31 PM   #1005
ds23man is offline ds23man  Netherlands
ds23man's Avatar
No
Old 11th September 2018, 02:18 AM   #1006
powerman is offline powerman  South Korea
What so special about MAQ? It's just a hype!
Old 11th September 2018, 02:43 AM   #1007
Julf is offline Julf  Europe
Indeed. MQA: A Review of controversies, concerns, and cautions - Reviews - Computer Audiophile
Old 11th September 2018, 04:05 PM   #1008
Originally Posted by newuserhify View Post
I tired to do as the guide, and still No sound.
Tried to turn the volumen op to max, and still No sound or wibration from My sub.
Any suggestion fore what to try next? 😊
problem fixed
1. wrong cabel.
2. not wired correct.
3. total noob
its it now wired as,
CH1 to sub 1
CH2 to sub 2
i have 2 subs in one cabinet, and was told to make a serie connection. but thats was wrong.
great sound and nice software
thanks to all for your time
Old 15th September 2018, 12:09 PM   #1009
Just to share the experience of the mode of green LED indicator light.
I've experienced the amp was unable to trigger after music played. The green LED light was flashing at the interval of ~2.5 seconds. It's fine ten mins before.
I checked the manual, the closer match was amp went into mute stage.
I couldn't even trigger the amp via the notebook therefore I switched off the amp, unplugged the power cord, and plugged it again. Powered up and the amp came alive again.
On the same day, it happened on the other amp. And this time round, I was very sure what was going on. It's because the power cord was loosen when I moved the amp during music played.
The green LED went to 2.5 seconds blinking mode (auto-mute, if I was correct) from steady mode.
Old 16th September 2018, 05:27 PM   #1010
kjb is offline kjb  Sweden
Originally Posted by Bingo1337 View Post
- I don't know exactly why, but I have the feeling that the DSP lacks of precision. If I run the same filter settings over my PC/RME for example and use it with an Hypex Amp it sounds much clearer and less then drifting away sometimes. Could this have something to do with the clocking? Does Hypex use Oversampling internally?
Have anybody compared the fusion amps dsp and dac and the dlcp? The dlcp have gotten god reviews for sq. So if these are equally good it should be enough. At least for me.
Linkwitz Lx521.4, Seas Mimir (active xo), ME2
Hypex (Apollon Audio NC502MP, NC252MP), Ucd250LP, Ucd400OEM, ESP P3A
The New Hypex Fusion Plate ampsHide this!Advertise here!
Hypex Plate Amps madtrapper Class D 1 14th March 2014 05:21 PM
Opinions wanted on using the Hypex 2.4 plate amps? SpinMonster Multi-Way 2 3rd April 2012 08:26 AM
Hypex plate amps chatziva Class D 3 29th July 2010 03:33 PM
HYPEX plate amps Glen1 Subwoofers 0 27th January 2006 02:22 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
