Class D investigation.
Old 12th February 2019, 06:33 AM   #131
Grizlek is offline Grizlek
Originally Posted by kees52 View Post
I have now I am waiting for parts, dis some sims with 5 and 8 level switching stuff.
The found stuff about the postfeedback with formulas do quite nice, I have use a 8 level, x 8 carrier is 2 Mhz and 100 Khz -3 low pass, maybe I can even go higher.
I do not now however how the switches go behave, because of the 8 levels, do go this into problems with audio, normally with a inverter for only 50 hz that is quite more relaxed then.
However I get with deadtime (if this is needed there?) quite low distortions, also on 20 Khz.
regards
May we see the schematics of this 8 level ? Signals do look very nice
Old 12th February 2019, 06:31 PM   #132
kees52 is offline kees52  Netherlands
Grizlek here are the 5 level class D and the open loop distortion, it is sim so in real live things get much worse, or I am lucky if not.
have include also a twree level self oscillating version, just build it, I like to see how it works in real live.
The 5 level has postfeedback however making the feedback filter oke, it needs calculation, carrier is x 4, so 250 Khz get 1 Mhz, can use smaller mosfets power gets evenly divided over mosfets..
Lib's are to big for put here, search on internet for them. or go here
For LTspice users. Libraries of models, examples, etc
regarts.
File Type: asc 5 level nonoffset-triangles-flycap3-oke5.asc (21.5 KB, 2 views)
Old 13th February 2019, 06:25 AM   #133
regarts.
How would you in real life make phase shifted triangles? And THD will be affected if that phase shift is good?
Old 13th February 2019, 11:56 AM   #134
Maybe like this? or use a chip and program it in it, there are a lot of nice cpu's like a FPGA chip.
You can go read over multilevel inverters on google a lot of info there.
I think more then 5 level for audio is because of parts count maybe not such idea, but you can set frequency to 150 khz and get on output 1.2Mhz making even output low pas higher and get 150 Khz bandwidth amp, but it is complicated for postfeedback.
Oke I get the parts for the circlotron so get to work after weeks of waiting because of other work and friend who did contract cancer and needs help, she did survive and is in remission.
regards
Class D investigation.Hide this!Advertise here!
Cathodyne investigation - stop the presses! exeric Tubes / Valves 40 29th June 2016 07:02 AM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 02:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 09:52 PM
Sony system failure - full investigation thread dmx2020 Solid State 11 19th October 2012 06:59 AM
My folded-cascode VAS linearity investigation GK Solid State 96 19th July 2010 11:01 PM
Copyright ©1999-2019 diyAudio
