Hi All
I have bought this board of eBay:
12V 24V 120W*2 TPA3116 Dual Channel digital Power audio amplifier board amp car | eBay
with a TPA3116. Works very nicely, with the exception that if you over-drive it with too much input signal, it cuts out. I guess this is to protect the device, but as I know the load that I am driving is nowhere near 2 or 4 ohms, I wont be sucking maximum amount of power, I want to turn this function off. Can this be done?
I haven't investigated the board yet, but looking at the datasheet for the TPA3116, I see there is a FAULTZ output pin, that can be joined to the MUTE input (by a transistor). Could this be my issue? Could there be anything else that is causing the output to MUTE?
Thanks for any advice you can give!
Mike
Mike
In class d when the input signal hits the rails the output becomes a 1 or a 0 for quite a long time. This causes the upper mosfet to lose its gate drive and the class d ic thinks there is a over current event as there is insufficient current through the mosfet.
The over current event shuts down the class d ic.
But I could be wrong.
[..eBay..]
Ofcourse it can. Don't push your amp into overdrive, limit your input signal, remove DC offset (yes, that's sometimes an issue even after an input capacitor, asymmetrical signal form is still an issue) and in doubt, measure and remove high frequency harmonics.
The Fault pin will only mute if it's detecting a fault (under-voltage, overcurrent, overvoltage, overtemperature, dc-offset, probably clipping (which I doubt in this amp) and short circuit). To remove it removes the symptom but not the cause.
Thanks for the replies.
So the only way is to to ensure that the input level remains below a certain level?A little more information about how the board is being used. It is connected into a public address system, where I am feeding the output of the board in to a 100 Volt line step up transformer, and connecting to 100 Volt line speakers along a long length of cable. I have 2 audio sources which I switch between. I set up the levels on the amp board for so that the 1st source (a PC) didn't cause the amp to cut out, however I have no control over the 2nd source level (a Mic). Ideally, what I would like is if there is too much input signal the amp board would go into a reduced gain mode, rather than turn off completely!
Would you have any further suggestions?
Once again, thanks for your time
Mike
Mike
- Class D
- TPA3116 Cutting Out
