FDA: Alientek D8
FDA: Alientek D8
Old 12th February 2018, 03:46 PM   #41
forestsgump is offline forestsgump
Originally Posted by audeo View Post
A minor correction: this "DDX" thing is related only to the output PWM and has nothing to do with any processing or lack of it before output. So, yes, "Tone" is the only setting in D8 which bypasses the internal DSP, but "DDX" can be switched on or off in firmware regardless of the DSP settings. I suppose, in D8 it is always on.
thks for point-out DDX... Ok got it DSP.
Old 12th February 2018, 07:53 PM   #42
Pavekk is offline Pavekk  Russian Federation
Guys, I need a firmware for the XMOS version, help!
Old 13th February 2018, 05:26 PM   #43
Launagis is offline Launagis  Lithuania
I've downloaded the driver from this site today:
Alientek D8 XMOS USB drivers and English: bravomail
works fine, but i''m not responsible if anything goes wrong
I have a few questions myself:
1) How to open the D8? I unscrewed all the screws, but the thing is still tight and not moving apart.
2) Which of the EQ positions i have to use to achieve the best sound? I assumed it was Flat, then read in manual, that it was Normal and someone suggested that it's Tone. I suspect the Tone is right, but it produces more bass than my Cyrus amp, so i'm not sure.
3) If i use weaker power supply (24v 3a), can it have impact on the sound quality (not the power)?
Old 13th February 2018, 08:20 PM   #44
audeo is offline audeo
Driver is not firmware, these are two different things.
Pull off the turning knob, unscrew the front screws, then remove the front panel and pull out the white ribbon from the front panel socket (carefully!), then unscrew 4 rear screws and pull the rear panel with the PCB and the outer box apart.
"Tone" is the most authentic (the least intrusive) EQ setting. Whether it is the best sound for you or not, only you can decide.
It should not until you try to get more power out of your amp then your PSU can provide to it.
Old 13th February 2018, 08:58 PM   #45
Thank you, audeo!
Old 15th February 2018, 08:13 AM   #46
No, not the driver, but the firmware.
The amplifier has broken down. The master said he needs a firmware.
Old 22nd February 2018, 05:38 PM   #47
It seems to me that volume level in Alientek D8 is controlled by altering the digital stream before feeding it to STA326 instead of using STA326's internal Master volume register. Can anyone confirm or deny it?
Old 24th February 2018, 05:04 PM   #48
gwingn is offline gwingn  United Kingdom
What is it that makes it seem so to you?
Old 24th February 2018, 10:58 PM   #49
I am trying to ID afew of the SMD on D8, anyone knows what are these based on their print and pin#:
1. 4B2R - 5 pin
2. 6x1 - 3 pin
3. 2F75 - 6 pin
4. MOP - 3 pin
5. 775J - 3 pin
Old 25th February 2018, 07:26 AM   #50
1. 4B2R - 5 pin
This probably is XC6204 - a 3.3V High Speed LDO Regulator with ON-OFF Control.
FDA: Alientek D8Hide this!Advertise here!
HiVi D8.8 in a TL kffern Subwoofers 15 31st December 2016 11:33 AM
HiVi D8.8 vs. Eton 11-581 Bass Drivers Steve M Multi-Way 8 27th December 2016 02:44 PM
2pcs Hivi D8.8+ Bass-Midrange ed9 Swap Meet 2 12th July 2016 02:38 AM
FS: FDA-1 balanced DAC Thomas Giz Swap Meet 0 4th April 2013 06:18 AM
FS: FDA-1 balanced DAC Thomas Giz Swap Meet 1 28th November 2012 05:29 PM
Copyright ©1999-2019 diyAudio
