TPA3255 - all about DIY, Discussion, Design etc.
Old 15th October 2018, 02:33 PM   #911
doctormord is offline doctormord  Germany
doctormord's Avatar
Point, i assumpted same efficiency for both tops and sub.
Old 17th October 2018, 05:50 PM   #912
jimk04 is offline jimk04  United Kingdom
So my MW SPV 300 48 .....fan spins all the time so I disconnected. It gets warm.....pretty warm. Not measured. Will do tonight.
Bought some 82r 2 watt res to slow it down. Soldered it all up. Fan still spins like hell. Realised I was sent 0.1R!
I also can hear the pwm of the smps. Even at decent levels watching TV. I must have bat ears.! It is just sat on the rack at the moment. It isnt in a case but I intended to run it this way but the noise will be a factor now.
What is normal temps for the 3255 board.? Or indeed safe temps for components? I have 3e. 48v and decent listening levels for an hour and more and coils and caps nudging 40c. Heatsink mid 30s. MW SMSP case is more than just warm.
Old 17th October 2018, 07:41 PM   #913
doctormord's Avatar
Without knowing your ambient temperature it’s hard to tell but 40degC fr coils n caps is just normal. The coils heat up the caps by radiation and trace conduction. Nothing to worry about. For the heatsink, they work best when they’re hot.
Old 18th October 2018, 07:15 AM   #914
Thanks doc. Ambient room temp approx 19C. Smps doesn't have a lot of free air. And is amongst other warm components.
I tucked it behind the centre speaker last night and is much quieter. Shame as I was going to put a nice wooden fascia on it and have it visible as I quite like the aluminium enclosure.
Old 26th October 2018, 08:03 PM   #915
Jakobie is offline Jakobie
Do you guys think a 57v supply is too much? I can get tons of these things for free and would be nice to use on the TPA3255.
Old 26th October 2018, 09:24 PM   #916
multisync is offline multisync  Canada
I think the max recommended by TI for a 6 ohm or greater load is 56 VDC. The absolute max rating is 69. Spike maybe or transient. A couple of diodes in series and you will be in the ballpark for a 6 ohm load. I will be doing the same thing.
I rescued a power transformer from an old dead 5 channel receiver. It gives 57.5 vdc with no load. I will put 2 full wave bridges in series.
check the power supply under load and see how much it drops,
Old 26th October 2018, 09:43 PM   #917
56.3V under 8Ω load
Old 29th October 2018, 12:29 PM   #918
doctormord's Avatar
Keep in mind:
"For load impedance ≥ 6Ω PVDD can be increased, provided a reduced over- current threshold is set."
Take note, that this is DC + Peak AC and includes filter ringing, switching spikes etc. at the output. I wouldn't recommend going further than 56.5V with reducted OCP-Trippoint.
Old 2nd November 2018, 01:51 AM   #919
pblossom is offline pblossom  United States
Default IEEE Article
Build Your Own Professional-Grade Audio Amp on the Sort of Cheap - IEEE Spectrum
The human capacity for self delusion is nearly infinite.
Old 9th November 2018, 08:54 AM   #920
MirageZA is offline MirageZA  South Africa
Default PFFB on TPA3255
Hello Friends,
My first post here :-)
I have acquired 2 TI modules, one for reference and other one for mods. So far I have replaced NE with OPA1612, there is subtle, positive sonic difference.
TPA3255 - all about DIY, Discussion, Design etc.-img_0092-jpg
For now, I'm using linear bench power supply, 30V/6A. I have noticed that both modules have ever so slight hiss (you really have to put your ear next to twitter) - OP amp change made no difference so I presume it's TPA3255 itself.
As I don't intent to play at full volume, I don't have a problem with lower gain and would like to try PFFB implementation, as per TI's schematics.
TPA3255 - all about DIY, Discussion, Design etc.-screenshot-2018-11-09-10-14-17-png
My question - is it worth to try? Coming from old school amplification, a little bit of negative feedback is good. How about 3255, can I expect lower noise floor (less hiss in my case).
In my view, PFFB is more elegant solution than coil/caps mods on the output.
Many thanks for your help!
Alex
TPA3255 - all about DIY, Discussion, Design etc.Hide this!Advertise here!
Inexpensive HDMI 2 channel receiver design discussion brw02005 Construction Tips 1 6th March 2016 08:27 PM
A Discussion on Design Philosophy - OB vs Multiway vs NOB miragem3i Multi-Way 2 10th July 2014 04:02 AM
Discussion: push pull design and minimal distortion does it matter ? hoppaz Subwoofers 19 15th November 2012 09:34 PM
Car subwoofer (2x8" fancy design discussion) VEC7OR Subwoofers 11 29th May 2004 10:12 PM
