Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Class D Switching Power Amplifiers and Power D/A conversion |
Thread Tools |
#3561 |
You re welcome, good purchase )
#3562 | |
Connex seem to be difficult to find in Europe and can be quite expensive. The Mean Well Power Supplies on the other hand are very easy to find and quite often available on eBay either used or as good as new. The Mean Well Power Supplies are very common in multiple manufacturers equipment and can often be found as excess stock or as spare parts. I bought a load of Digipos 24 volt 250 Watt Power Supplies for less than £10 each. They are Mean Well SP-240-24 in a nice plastic case. Adjustable voltage up to about 30 volts. You just have to disable the remote control feature unless of course you want to use it to turn on the Power Supply remotely.
Aiyima A04 and A07, 3e-Audio DAP1002 and 2 Channel Board, KEF Q10 Speakers. I provide PA equipment for Charities and local Clubs and Societies for their meetings inc. ChudFest. |
#3563 | |
Some of the Power Supplies you have listed are dual rail and not suitable for TPA325x amplifiers that use a single rail. Unless you are going to drive all your amplifiers flat out then you probably don’t need such high capacity supplies. Also the heat sinks on most of the TPA325x boards are too small to run at the full specification for any period of time !!
#3564 |
I was aware that it could be a problem with dual rail, must have missed it with the ones I posted.
![]() The 'problem' with the Meanwell that's lower output seem to be that they either have 24V or 36V, but they say that it's 10% adjustable so 24V should work for the 3251. The ones with less Watt also have a higher R&N value, but maybe it's of low consequence going from 150mV to 200-250mV... ![]() Or is it possible to use something in-between the PSU and Amp to clean up the signal, capacitor perhaps..? The MW RSP 500W in 27V and 48V is what I'm looking at right now. (Yes, I'm new at this. lol ) |
#3565 | |
More distortion to the people! Timing . . . . is paramount. |
#3566 |
TNT it's on backorder right now.
Does it work with 36V for that Amp? I have found MW RSP 500W 27V for about the same price as that Connex as well. |
#3567 |
Aha - sorry!
But if you think you can live with 35V you can get the 32V which seem to be in stock.. From Connexion page: "The stock available output voltages are adjustable within approx. 10% and the ordered voltage value is at the middle of the interval. For example the 24V version can be adjusted from 22.5V to 26V." For a 32V it would mean 35V. Higher voltage keeps the amp delivering high output in higher impedance speakers. If you are on say 4 ohm, the lower voltage ones are fine. Also less heat. //
More distortion to the people! Timing . . . . is paramount. Last edited by TNT; Today at 12:28 PM. |
#3568 |
We might make our LLC PSU available . 275W continuous , 50V and 15V output.
Noise on output 1.5uV (20Khz bandwith) or less up to 100W. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Inexpensive HDMI 2 channel receiver design discussion | brw02005 | Construction Tips | 1 | 6th March 2016 08:27 PM |
A Discussion on Design Philosophy - OB vs Multiway vs NOB | miragem3i | Multi-Way | 2 | 10th July 2014 04:02 AM |
Discussion: push pull design and minimal distortion does it matter ? | hoppaz | Subwoofers | 19 | 15th November 2012 09:34 PM |
Car subwoofer (2x8" fancy design discussion) | VEC7OR | Subwoofers | 11 | 29th May 2004 10:12 PM |
New To Site? | Need Help? |
