Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Class D Switching Power Amplifiers and Power D/A conversion |
Thread Tools |
#3251 | |
I guess rolling appropriate OP amps depends a lot on the Inductors as well + synergy with the input caps. You will find some measurements in 360 Customs site about this. My last improvements on DrModor Module : ![]() Last edited by daniboun; 4th December 2020 at 08:01 PM. |
#3252 | |
#3253 |
Hi amigos,
Just to share ) TAS3251 with internal DSP, quick test at home (video) > VID_20201012_191848 ![]() taille image en ligne Last edited by daniboun; 4th December 2020 at 09:50 PM. |
#3254 |
this is a full audio digital amp (fda) whith the latest chip of TI ?
![]() Last edited by mamocel; 4th December 2020 at 10:19 PM. |
#3255 |
I2s usb conected !miam!
#3256 |
#3257 |
Is this one of JMF11's NeatAmps? That is an interesting project, but it is hard for me to get a feel for the final outcome. It would be nice to have a great amp that plugs directly into my RPi without messing around with a DAC. The HiFiBerry Amp100 looks great in terms of plug and pla but the specs are underwhelming.
#3258 |
Exact ) I met JMF11 a few weeks ago.
We have tested his TAS3251 vs TPA3251 with OPA1656 + updated inductors vs Dual Mono Infineon Merus It was a super interesting listening session anyway ) The main interest of the TAS3251 is precisely to integrate a DSP) otherwise you might as well opt for a TPA3251.... As you can see, this TAS3251 does not have any OP amps, the signal is processed in the chip My next challenge is : to propose to "la maison du haut parleur" (very famous shop in France), via an expert's opinion, a comparison between my future Purifi amp with a custom buffer VS the new Dual Mono Gan DrMordor VS the TPA3255 DrMordor. I expect a lot from Drmodor Gan dual Mono modules. Everything is already on the way... January should be an interesting month) Last edited by daniboun; 5th December 2020 at 07:16 AM. |
#3259 |
JMF11 shared his opinion of the comparison, and it seemed that the NeatAmp was a good match for his tastes. How about for you? How did it sound compared to the other TPA3251 amps you have like the Aiyima or the 3e-Audio? Your Aiyima is heavily modified, any sense of how it sounds compared to a vanilla Aiyima?
#3260 | |
I2s i think. Last edited by mamocel; 5th December 2020 at 07:41 AM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Inexpensive HDMI 2 channel receiver design discussion | brw02005 | Construction Tips | 1 | 6th March 2016 08:27 PM |
A Discussion on Design Philosophy - OB vs Multiway vs NOB | miragem3i | Multi-Way | 2 | 10th July 2014 04:02 AM |
Discussion: push pull design and minimal distortion does it matter ? | hoppaz | Subwoofers | 19 | 15th November 2012 09:34 PM |
Car subwoofer (2x8" fancy design discussion) | VEC7OR | Subwoofers | 11 | 29th May 2004 10:12 PM |
New To Site? | Need Help? |
