TPA3255 - all about DIY, Discussion, Design etc.
Old 20th October 2020, 09:49 AM   #2841
drMordor is offline drMordor  Russian Federation
Resistor 3-10k
No need film caps, need MLCC
Sorry, my english bad))) But I'm learning!
Old 20th October 2020, 10:28 AM   #2842
saran008 is online now saran008  Singapore
Originally Posted by drMordor View Post
Resistor 3-10k
Thanks for the guidance Doc.
Any brand/value for MLCCs?
any thumb rule for calculation?
if I use 22000uf x4 will it be overkill? any negative effect?
SLPX223M050H9P3 | Cornell-Dubilier 22000μF Electrolytic Capacitor 50V dc, Through Hole - SLPX223M050H9P3 | RS Components
FYI My SMPS is below link, customized for Single 42V.
GHXAMP HIFI Switch Power Supply Dual DC 24V 48V 60V 80V 300 500W Power Supply Board With Heat Sink For Low power Amplifier 1pc|Amplifier| - AliExpress
Old 20th October 2020, 12:17 PM   #2843
Any, 100V 1-10uf
No need add caps for SMPS.
Old Yesterday, 01:00 AM   #2844
Ok Doc. thanks for the clarification.
If I add caps, will it have any negative effect?
Old Yesterday, 03:26 AM   #2845
Need to listen)
Old Yesterday, 03:38 AM   #2846
opc is offline opc  Canada
opc's Avatar
Depends on the power supply... too much capacitance can impact the OCP or startup of the SMPS, causing a "hiccup" where the supply will try to start, charge the added caps, then go into OCP, and get stuck in a cycle of perpetually trying to start up.
Also, an SMPS does not work the way a traditional linear supply does. They generally use feedback for regulation, so they don't need massive banks of caps to maintain good regulation. Adding capacitance to a typical SMPS it likely to cause more problems than it will solve.
Owen
Old Yesterday, 03:40 AM   #2847
+100500
Old Yesterday, 03:51 AM   #2848
Need to listen)
Originally Posted by opc View Post
Depends on the power supply... Adding capacitance to a typical SMPS it likely to cause more problems than it will solve.
Thanks Doc & Owen. Anyway I already ordered the pcb.
once I receive the pcb, will check the lead spacing, order the caps (22k uf x 1 first and check)
is this 22000 uf model ok?
at output it has only one 1800uf 50V
  Reply to this post
TPA3255 - all about DIY, Discussion, Design etc.Hide this!Advertise here!
Inexpensive HDMI 2 channel receiver design discussion brw02005 Construction Tips 1 6th March 2016 07:27 PM
A Discussion on Design Philosophy - OB vs Multiway vs NOB miragem3i Multi-Way 2 10th July 2014 03:02 AM
Discussion: push pull design and minimal distortion does it matter ? hoppaz Subwoofers 19 15th November 2012 08:34 PM
Car subwoofer (2x8" fancy design discussion) VEC7OR Subwoofers 11 29th May 2004 09:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
