TPA3255 - all about DIY, Discussion, Design etc.
Old Today, 01:20 PM   #2351
potstip is offline potstip  Turkey
Originally Posted by bucks bunny View Post
Meanwhile I had some ideas for improvements that ended in additional iterations of the TPA325x-PBTL pcb-design. Actually that is the news:
+12V Sync-buck-regulator extended to “flybuck” providing +-12V symm supply for op-amps.
10pin IDC-connector added to connect via ribbon cable a new control pcb providing 4 operating status LEDs and another 10pin port for diagnostic measurments.
Replacing output inductors by latest Würth HIDE-series with small footprint.
PCB dimensions shrinked from 100x75mm down to 100x62mm.
IN PBTL mode according to datasheet support 2-4 ohm. what about 8 ohm?
Old Today, 01:21 PM   #2352
Originally Posted by cdsgames View Post
I was able to improve EVM of 6.67Khz/10W/4R (non PFFB) from 0.012% to 0.005%
With PFFB (while not tested) I would expect it to be 0.0025%, Our goal is to make it around 0.001 % at a max
What I did , is tryed over 20 inductors and ended up making a custom one. As you can see inductor influences distortion by quite a good amount .
Can you share custom inductor details. I want to try on my board.
  Reply to this post
TPA3255 - all about DIY, Discussion, Design etc.Hide this!Advertise here!
Inexpensive HDMI 2 channel receiver design discussion brw02005 Construction Tips 1 6th March 2016 07:27 PM
A Discussion on Design Philosophy - OB vs Multiway vs NOB miragem3i Multi-Way 2 10th July 2014 03:02 AM
Discussion: push pull design and minimal distortion does it matter ? hoppaz Subwoofers 19 15th November 2012 08:34 PM
Car subwoofer (2x8" fancy design discussion) VEC7OR Subwoofers 11 29th May 2004 09:12 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
