TPA3255 - all about DIY, Discussion, Design etc.
Old 21st May 2019, 02:37 AM   #1231
KCN is offline KCN
My amp now starts well, plays good for few minutes and then the sound slowly drops till you can hardly hear. some times it increases again and falls or some times remain ultra low voulme.
switching on and restart immediately has no effect. but switch off for 5 minutes and restart sound at normal volume and then again it slowly fades.
what may be the reason for this?? tried on multiple input source both bluetooth and dac/preamp.
running on 32v dc powersupply checked it and has steady output
Old 21st May 2019, 08:09 AM   #1232
Turbowatch2 is offline Turbowatch2  Germany
I often read about D-amps having problems with Bi-amping loudspeakers.
This is a logical result on many designs!
The midd/ high part of a bi-amped speaker is a "no-load" situation for the lower frequency.
So if the amp does not like beeing driven with open output, it may fail or produce all kinds of problems, like overheating or sudden shut down, some even burn the chips internals.
So, first check the amps capabilities, then connect!
The "right way" of bi-amping is a two way active configuration, that eliminates the passive x-over. Often these two completely different topics get thrown into one bowl.
Old 21st May 2019, 08:13 AM   #1233
@KCN
check the mute pin of your amp, it might charge up and enable itself after some time. Read the data sheet and compare your specific implementation. Maybe some safety feature engages?
Old 21st May 2019, 10:19 AM   #1234
AnatoliyHill is offline AnatoliyHill
Hi, Mate. What do you mean check the mute pin? What status/ voltage it should be and how to reset it?
Old 22nd May 2019, 07:35 AM   #1235
chermann is offline chermann  Austria
Hi anatoliy
i guess turbowatch is mentioned a circuit to avoid a faster power up of the TPA chip. i mean : if you switch on the amp board the rail voltage starts to rise and the tpa chip wants to "switch on" and therefore you will here this pop on sound.
to avoid this there is a circuit at the mute pin to "hold" the tpa chip "mute" = quiet.
at the YJ tpa3255 board there is a voltage superviser chip on board to do that.
-->TPS3802...please read some posts...its not so easy
What is wrong with TPA3255?
doctor created this circuit....
this mute circuit can be done with some RC divider too..pic 2
chris
Old 22nd May 2019, 07:47 AM   #1236
hi turbowatch2
can you explain this:
chris
Old 22nd May 2019, 09:21 AM   #1237
doctormord is offline doctormord  Germany
doctormord's Avatar
The second circuit doesnt make sense here and will fry the TPA inputs due to overvoltage.
Old 22nd May 2019, 09:50 AM   #1238
yes you are right...its bad to show the principle of the circuit with wrong values....
sorry
Old 22nd May 2019, 12:17 PM   #1239
doctormord's Avatar
It is not showing the principle of the circuit, it behaves completely different. (As it is totaly different)
Old 22nd May 2019, 03:35 PM   #1240
KCN is offline KCN
My speakers are not bi-amped. No mute pin in schematics.
i have changed the caps that i had put in earlier, even put lower value caps but same result.
the music plays normally and then reduces in volume. it is not complete mute. some times the voulme ebbs and dies but the sound is there at very low volume.
The large input cap near the dc jack? will and problem in that cause such result, as if the amp input current is fluctuating?
any input/help welcome.
TPA3255 - all about DIY, Discussion, Design etc.Hide this!Advertise here!
Inexpensive HDMI 2 channel receiver design discussion brw02005 Construction Tips 1 6th March 2016 07:27 PM
A Discussion on Design Philosophy - OB vs Multiway vs NOB miragem3i Multi-Way 2 10th July 2014 03:02 AM
Discussion: push pull design and minimal distortion does it matter ? hoppaz Subwoofers 19 15th November 2012 08:34 PM
Car subwoofer (2x8" fancy design discussion) VEC7OR Subwoofers 11 29th May 2004 09:12 PM
Copyright ©1999-2019 diyAudio
