TPA3255 - all about DIY, Discussion, Design etc.
Old 22nd February 2019, 11:34 AM   #1011
doctormord is offline doctormord  Germany
doctormord's Avatar
Originally Posted by AnatoliyHill View Post
Wow, Dear Think mentioned original topology contain 2#4700mkF which almost double more I have in my box. Is this a main reason for lack of bass I am having? Furthermore I have only one capacitor enstead of two, think it worth to take of sink enable mates see the topology for further decision.
As written already - no.
Old 22nd February 2019, 12:44 PM   #1012
Think is offline Think  Netherlands
Sin Bin
Thx again people.
@chermann; thx for the tips I won't use the power supply or booster again. The power adapter seems to be fine though, the booster not.
@ jimk04; csmt is short for Customer Support Management Team?
@ doctormord; should I make a topic at TI's forum or email them?
Old 22nd February 2019, 02:07 PM   #1013
doctormord's Avatar
I'd mail them first, it's the "high power audio" department.
You may consider dropping "frammis" a private notification here in the forum, he's "somewhat" related to these chips.
Old 22nd February 2019, 03:02 PM   #1014
zeroFILL is offline zeroFILL
After a long time following this thread, I decided to order a TPA3255 board, and it just came yesterday Very nice!
Thank you all for sharing your knowledge and passion!
BTW, I'm going to add a potentiometer to control volume, so which value to chose? Is a 50k Ohm one will work? Thanks!
Old 22nd February 2019, 03:02 PM   #1015
Sin Bin
Arrow Pic's of the horror scene came out better then expected.
It looks to me that the PVDD pins have arced to the heatsink (there is a little pitting) and not to 1 of ground pins or caps nearby.
//edit: thx again doc, I will do that.
and bigger pics can be found here
https://i.postimg.cc/HxL87mZD/1-DSCF5569.jpg
1 DSCF5577 — Postimage.org
1 DSCF5584 — Postimage.org
1 DSCF5594 — Postimage.org
1 DSCF5602 — Postimage.org
( did not work out as I like, sorry)
Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
Last edited by Think; 22nd February 2019 at 03:14 PM. Reason: postings in the mean time.
Old 22nd February 2019, 05:23 PM   #1016
jimk04 is offline jimk04  United Kingdom
No sorry that was my phone auto correcting 'cant' to 'csmt ' for some reason!
Old 22nd February 2019, 05:43 PM   #1017
Sin Bin
Thx, that makes sense.
Offtopic; probably the same season I could not get the picture thing right even though I used to make websites in the early days.... it should be simpler now... somehow or is it only me who got simpler as time goes by? :?
Tinypic was down, so I thought let's try something else.
Old 26th February 2019, 05:34 PM   #1018
doctormord's Avatar
So, in the end they found together, TPA3255 2.1 100x100mm system in direct contact with the 1200W 4-phase LTC3784 boost-converter board, making it possible to go the distance with even only having 10V at the input to put out 600Wrms. As this asks for 1200W power into the amp and an realistic efficiency of 92% from the boost converter, this setup is asking for 130A at the 10V input. (Things get much easier when using a 36V supply) For the AFE module and bulk caps there is a mounting holder within half of the height to make good support for stability while driving with the bike. The whole thing measures 110x110x70mm, i'd call this a power-brick.
TPA3255 - all about DIY, Discussion, Design etc.-img_20190226_134652-jpg
TPA3255 - all about DIY, Discussion, Design etc.-img_20190226_134754-jpg
TPA3255 - all about DIY, Discussion, Design etc.-img_20190226_134907-jpg
TPA3255 - all about DIY, Discussion, Design etc.-img_20190226_134943-jpg
Bike? The bike with the actual setup, TPA3255 + 3x12V SLA system...
Youtube: YouTube
Old 27th February 2019, 08:31 PM   #1019
Sin Bin
Very nice!
1) Did you do some measurement of maximum continues power draw?
2) Is passive cooling OK with 36V?
3) How many Ah are the SLA's and do you have an indication of run time?
To power a 600W AB car amp at high volume, a laptop and a tiny usb powered mixer for 8 hours I needed to bring 2x 12V 105Ah deep cycle batteries (2x20+kg) .... and could warm my hands on the amp. As I could only draw them to 50%, that is only a bit more then 1kwh.
I intend to use a 36V 8.4AH (0,3kwh and 3kg) ebike battery which was given to me as defective but is fine with only a new fuse on the charging port.
I estimate it will run more then 8 hours.
The Hooverboard /Oxboard (2 wheel kids balance toy) batteries might be interesting to use. They are 2p10s 18650's, 36V 4.4AH often Samsung cells and sell for €40. I know an address to pick up defective packs for €5 of which most prob. need a new bms as they are tortured (rigorously tested ) by the 2x 250w motors going back and forth.
Old 28th February 2019, 06:09 AM   #1020
doctormord's Avatar
Short answer first:
1: What measurements are you looking for, amp or boost? i have plenty of documents/measurements done
2: yes, even in an closed enclosure
3: I use 3x5Ah deep cycle cells, so about 60Wh which will do about 5-6hours at early full power. (The speakers are better than 96dB. With the all new 36V 10s4p 11.8Ah pack which is about 420Wh, the amp theoretically will run 42 hours.. but i want to use them in a 30-80% manner, so charging only to 4.00V and discharge only to 3.3V per cell at normal.
The 10s2p packs might struggle on peak power performance, if not the cells, then the BMS. I have one of these packs here, with fake Samsung cells and rusty BMS, sold as brand new...
TPA3255 - all about DIY, Discussion, Design etc.Hide this!Advertise here!
Inexpensive HDMI 2 channel receiver design discussion brw02005 Construction Tips 1 6th March 2016 07:27 PM
A Discussion on Design Philosophy - OB vs Multiway vs NOB miragem3i Multi-Way 2 10th July 2014 03:02 AM
Discussion: push pull design and minimal distortion does it matter ? hoppaz Subwoofers 19 15th November 2012 08:34 PM
Car subwoofer (2x8" fancy design discussion) VEC7OR Subwoofers 11 29th May 2004 09:12 PM
Copyright ©1999-2019 diyAudio
