Class D vs Class AB
Class D vs Class AB
Old 9th October 2019, 07:17 PM   #91
Turbowatch2 is offline Turbowatch2  Germany
In my youth, the first CD was the turning point for HIFI. After years of people being proud of having a hole corner full of different gear cabled up, I and a lot of other people, realized that all this stuff didn't help much with sound.
My first CD player had two outputs, one went over a mechanical potentiometer, one direct.
I spent, if I remember right, two years trying different pre-amps, until I found one that had no sound added or removed from the signal. I could live even without a pre for listening, but as I build speakers, I needed a balance and mono function for A/B comparisons.
The one I found had exactly what I needed and was on sale for a ridiculous price. Most important was the mono switch and for real listening, the option to take all tremble, bass, loudness out of the way. Was a Fisher CC-3000. I still use it.
The next pre-amp that came in at par was an AVM Evolution V1 in 1992. Still in use at a friend of mine. These are very basic amps, reduced to some relays and a simple adjustable power stage with high voltage output.
The often used passive pre is only a solution for some cases, as many amps do not like to be driven by a resistor (pot).
So yes, keep it simple, keep (cables) it short.
The AVR´s bad sound is not with all of them. There are very good sounding AVR´s on the market. It depends on how you use them, too. Today you will not get around DSP processing, somewhere in the chain. At last the producer of your source used one...
So, these bashing digital equipment are on the wrong way. It is, IMO, better to sent your signal through some DSP and let it do the separation of frequency, than to use 3 pounds or more of passive L, R and C to do the job.
Yes, not too much stages, but enough to get a good result. Even as there might not be two people in the world selecting the same components for this task...
so what will be the final result?
Class D vs Class ABHide this!Advertise here!
Class-AB meets Class-D: Yamaha's EEEngine Topology - where are this Diy Projects? tiefbassuebertr Solid State 77 17th February 2019 05:07 PM
Leaving class A how to make this amp leave class A to AB when volume is increased? rhythmsandy Solid State 3 14th June 2016 01:16 AM
Contest: Linear Power Amp in a mint tin (class Aa, class AB, or class B) danielwritesbac Chip Amps 206 19th January 2013 08:52 PM
does class A amp feel more powerful with same ratings compared to class AB? rhythmsandy Solid State 7 10th December 2012 05:21 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
Copyright ©1999-2019 diyAudio
