Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Class D Switching Power Amplifiers and Power D/A conversion |
Thread Tools |
#1001 |
Banned
Btw, where can we find Dr M. 3521 pcb offer ? (be it populated or not)...,? I have not been following the thread lately !
#1002 |
@cloud, did you got your boards up and running?
#1003 |
yes one of them still not put it in case and using a 32v smps of poor quality and yet im still very impressed with the sound considering i have only had 5 hours of listening i have a feeling it will replace my trupath ta3020 in my system waiting for connexelectronic power supply then it's time to make it really sing
do you think a LDR pre amp stage would make a good partner for this build? Last edited by cloud1972; 6th July 2016 at 11:29 PM. Reason: spell mistake |
#1004 |
Never used an LDR stage.
#1005 |
Finally managed to get my case done.
![]() TPA3251 (TPA3255) aka ?Model Tiny? in Aluminiumgehäuse ? #360customs TPA3251 "Model Tiny": Hope to get the revision done on the blue board soon to order some new boards. (Finally for the DIYers)
#1006 |
Nice, Doctormord!
I'm curious about the thermal bridge. I've seen the photos on your site, but I'm not clear on a few things. Is there just one? Is it affixed to the case, or the board/chip? Is there just one silicone pad? You refer to the plates as "soldered" do you solder them to the top of the chip, or did you build them up be soldering together thinner sheets? Thanks. |
#1007 |
Thanks for the question. The heat bridge consists of 3 copper sheets which are polished first and then soldered together by reflow and solder paste. This then gets connected to the case by the thin thermal pad as the case isn't that flat due to the manufacturing process of extruding. The thermal connection between the 3251's thermal pad and the heat bridge is just "press fit" without any grease as the thin top copper sheet is rather soft.
Doing so, the heat bridge sits straight and tight on the 3251's top pad with minimal thermal resistance, any non-flatness is carried out by the thermal pad. The solution is able to handle 100Wrms (or 2x50Wrms) continuous output power at 30°C ambient. Thermal flow is quite good as the case is heating up quickly to about 60°C. With an efficiency of 90% there's 10W thermal loss at 100W output power, so the solution is at ~3K/W. When listening to music higher output power isn't a problem due to "burst"/crest factor. The only limiting factor then is the inductors saturation current limit at ~8A.
#1008 |
Cool, thanks for the details!
#1009 |
doctoemord are you selling the small boards or just the larger boards to diy'ers. I would love to get a pair of boards to go with some prototype work I am doing. It will be one part of a development project using the ADAU1701 chip.
Thank you, Steven |
#1010 |
@doctormord: Do you have any update on the amps/boards? Thanks.
Thread Tools | |
New To Site? | Need Help? |
