200W IRS2092 Amp for
Old 21st September 2019, 03:49 AM   #521
Turbowatch2 is offline Turbowatch2  Germany
Hans, sometimes you do strange things for unclear reasons. Maybe the amp has died now, because he was happy the way it was and needed the regulator it had? Why remove a working regulator and install a problematic step down? An oscillating problem that other people would, maybe, remove out of an audio device?
There is a saying: Do not fix it if it is not brocken. This makes some sense, donīt you think?
Do you have a schematic for the amp? If yes, someone could figure out what you did and why the amp responded like it did.
If no, no one can tell you what you did. Do you have any idea?
Old 21st September 2019, 07:17 AM   #522
hansueli is offline hansueli  Switzerland
Thanks for answer
The problem was that with 48v the regulator got to hot.
I have schematics.
On similar amplifier the use step-down for vcc.
That was the reason.
With new power supply in future I will not have this problem any more...
Old 23rd September 2019, 12:04 PM   #523
So you got it working again? Great!
Old 23rd September 2019, 12:10 PM   #524
You can get the regulator input voltage down by simply using some resistor to turn the too high voltage into heat. A passive solution might be less complicated.
Alternative: Use a pre-regulator, so the load is shared between the two.
Old 23rd September 2019, 12:11 PM   #525
No
I have no response from the ICs
Thats the schematic and the VCC part... I think this have bruned the IC...
Old 23rd September 2019, 12:15 PM   #526
Maybe try to open the schematic after posting?
I can not see anything...
Old 23rd September 2019, 12:19 PM   #527
Some times IMGBB has some problems...
Sorry.
Old 23rd September 2019, 02:19 PM   #528
Boydk is offline Boydk  Denmark
Not to be an ***, but is it possible, that you broke some of the "platings"?? (donīt know if itīs the right word for the tiny copper tubes that go from top to bottom of the pcb connecting all layers) when you removed the old capacitors??? If itīs made as a 4-layer PCB, the damage is not repairable. I 2-layer you might be lucky to find such an error. Also one of my friends found a slight reverse leak in the diode that goes to pin 15 when his version died just out of the blue. Replacing it with a MUR120 solved it.
Old 23rd September 2019, 02:26 PM   #529
the amp does not smok or something.
So it could be no problem in PCB
Old 23rd September 2019, 04:19 PM   #530
Thatīs no guarantee..... Broken supplylines, and the crap doesnīt work anymore. Nor does it smoke/burn
200W IRS2092 Amp for Hide this!Advertise here!
L-20 200w class b amp ljm_ljm Solid State 5 3rd October 2011 04:04 PM
Parts Express DOTD 20-0-20 200W transformer $5 officeboy Parts 20 21st June 2010 10:02 PM
Another amp with IRS2092 mag Class D 23 18th June 2010 08:25 PM
Power Amp Toroids 20-0-20 VAC 500 VA daedalus Swap Meet 17 24th May 2006 08:30 PM
Need a transformer? 20-0-20 200W $5 officeboy Chip Amps 3 24th March 2004 02:55 AM
Copyright ©1999-2019 diyAudio
