Which 2.1 TPA3116D2 to go for?
Old 22nd December 2014, 01:33 PM   #1
perceval is offline perceval  Taiwan
perceval's Avatar
Default Which 2.1 TPA3116D2 to go for?
Looking for a TPA3116D2 to play with, I have access to a few, some with OP amps, some with caps, ... it can be hard to navigate through the lot and quite easy to get lost!
Don't have much experience with class D amps, so turning to the "pros"
Here's a short list of some of the 2.1 boards available, in 50W+50W, +100W.
Old 22nd December 2014, 03:04 PM   #2
smile2 is offline smile2
Where can you buy the 4th amp?
Old 22nd December 2014, 03:17 PM   #3
perceval's Avatar
They are all available to me locally... in Taiwan.
Old 22nd December 2014, 03:30 PM   #4
irribeo is offline irribeo  Netherlands
4th only with short speakerwires, then probably most interesting one
Old 22nd December 2014, 03:33 PM   #5
perceval's Avatar
This one? Short speaker wires? Meaning not a long run between the amp and the speakers? I may need about 2 meters of cable between amp and speaker.
Old 22nd December 2014, 03:58 PM   #6
I believe TI specifies ferrite bead filter is within FCC (how is radiolaw where you live?) with twisted speakerwires till 1.5 or 2 meters. In Japan it is probably not legal, very strict laws there This board has FB on output, so no peaking outputfilter with any speakerload, also less distortion and better efficiency?? probably, if chip isn't tempted to become a radiotransmitter
Old 22nd December 2014, 06:13 PM   #7
ForenSeil is offline ForenSeil  Germany
Couldn't you simply put it in a metal case?
But cables have less resistance than thin copper layer on the PCB I guess (?)
Old 22nd December 2014, 06:26 PM   #8
Yes maybe when you keep speakers and all wires within case too. In Japan would say: only allowed for laboratory usage
Old 23rd December 2014, 07:06 AM   #9
perceval's Avatar
Are there any boards allowing an adjustable crossover?
Most of those boards just let you adjust sub output volume and mains L/R output volume, then overall volume. Meaning the full range of frequencies are sent to both mains and sub lines.
Old 23rd December 2014, 07:58 AM   #10
doctormord is offline doctormord  Germany
doctormord's Avatar
Well, measuring the TPA3132D2 (Simililar to the 3116/3118) with only fb-filters transmits some "noise" but not that much to worry about.
(Measured at PVCC=20V with 8Ohm speaker at 0.7m speaker wire, HMS3010, HZ551 probe at 1m distance)
Amp on, idle:
Which 2.1 TPA3116D2 to go for?-26_300mhz_amp_diff_freq-png
Those "peaks" are just harmonics of the switching frequency, better seen here:
Amp off:
Which 2.1 TPA3116D2 to go for?-34_50mhz_amp_off-png
Amp on (idle):
Which 2.1 TPA3116D2 to go for?-1_50mhz_amp_on_idle-png
Which 2.1 TPA3116D2 to go for?Hide this!Advertise here!
TPA3116D2 Amp mguntrum Class D 10790 3rd December 2018 06:43 AM
My TPA3116D2 design (opinions please) sajrohan Class D 1 10th September 2014 06:53 PM
TPA3116D2 Sound Issues aspaeth Class D 10 1st July 2014 04:20 PM
TPA3116D2 amplifier ClefChef Swap Meet 0 25th March 2014 08:30 PM
