TPA3116D2 Amp
TPA3116D2 Amp
Old 18th October 2016, 01:03 PM   #9621
fulvio is offline fulvio  Italy
Originally Posted by Yatsushiro View Post
Could you possibly post pictures of what goes where? I have done a similar mod to my Audiobah clone, so have the resistors and capacitors to hand.
R=4x10 ohm, C=4x330 pF
Capacitors are connected to PCB ground plane after scratching the paint in two points.
By the way, a piece of 2.54mm strip contact can be used as input connector (can be seen in first picture)
Old 18th October 2016, 01:13 PM   #9622
Yatsushiro is offline Yatsushiro  France
Thank you, will get soldering tonight!
Old 18th October 2016, 02:50 PM   #9623
jwicaksana is offline jwicaksana  Indonesia
Originally Posted by jwicaksana View Post
Finished board
Friends, will I get a benefit if I change the inductors with:
5pcs 12127MM 10uH Mark 100 SMD Shielded Power Inductors | eBay
5PCS CD75 10uH 100 SMD Power Inductors 7mm5mm
No audiophile part, but proper value for the board. My speaker is 6 Ohm. Thanks.
Jonathan
Old 18th October 2016, 09:39 PM   #9624
Angeldust is offline Angeldust
With stock board the inductors of the slave chip are getting hot but as fulvio suggested I remove c33 to have better synchro.After that things cool to normal.Click the image to open in full size.
Sent from my HT3 using Tapatalk
Old 18th October 2016, 11:08 PM   #9625
sphykik is offline sphykik  United States
The gain is 32 dB (40x), but, driving the input directly with a low impedance source, no noise is audible; modification of the gain is not easy, because to do this you have to remove the heatsink, that is glued over the SMD components (not fixed with screws as in the seller pictures).
Concerning the supply capacitor (4 x 470uF), in my board they are not Sanyo (as in the seller picture), but they are marked JWCO LOW ESR; assuming they are not fake, according with JWCO datasheet, they should have an ESR of 65 mohm and a ripple current of 1200 mA, each one: not so bad!
Here are photos of the Amazon board. It has a removable heatsink, and the caps say SANYO - however I'm not sure if they legitimate. Perhaps someone can weigh in...
Old 19th October 2016, 12:43 AM   #9626
Got out the magnifying glass and...
39 kΩ in R1
100 kΩ in R2
For gain of 32db per the data sheet
Input caps are 1μF, which gives a -3db response at 20hz. Should be changed to 5.6F for a flat response to 20hz at 32db gain.
Amazon link again for those that are interested. These are good boards and have the largest heatsink you can find around right now. There are ~12 left.
Just bought 2 more!
Old 19th October 2016, 06:06 AM   #9627
Wow nice. Do you hear any difference in sound? What other mod did you do on your board? Thanks.
Jonathan
Old 19th October 2016, 08:19 AM   #9628
irribeo is offline irribeo  Netherlands
Like I said very obvious counterfeits. Millions around, some look better than these.
If one wants the Sanyo WX buy the Suncon ME-WX at an official distributor. Yes the Sanyo should read Suncon on the foil and if buying old stock one should at least take a look at the Suncon to see if the Sanyo is close enough to even wait for seller to send other capacitors than pictured in the ad on Ali or Ebay
Old 19th October 2016, 11:57 AM   #9629
39 kΩ in R1
100 kΩ in R2
Just bought 2 more!
For G = 32 dB, Rin is 15Kohm, so with Cin= 1uF, the -3dB point is about at 10 Hz; at 20 Hz, the loss is about 1 dB; I wouldn't worry for this.
Old 19th October 2016, 02:30 PM   #9630
No other mod yet but I want to remove the four capacitors.Can't tell nothing about difference in sound quality but for me this board is worth the money I pay(6.8 dollars).
TPA3116D2 AmpHide this!Advertise here!
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 02:17 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 03:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 09:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 10:28 AM
Copyright ©1999-2019 diyAudio
