TPA3116D2 Amp
TPA3116D2 Amp
TPA3116D2 Amp Please consider donating to help us continue to serve you.
Old 12th December 2019, 02:10 PM   #11351
jwicaksana is offline jwicaksana  Indonesia
Hi FauxFrench, thanks for being courteous, and generous with your time and expertise..
Just passing to say that..
Jonathan
Old 12th December 2019, 02:18 PM   #11352
FauxFrench is offline FauxFrench  France
Many thanks Jonathan, very much appreciated.
Also I learn a lot from being forced to think about how things really relate and how to explain it to others in an understandable way.
Old Yesterday, 08:24 PM   #11353
Zoran023 is offline Zoran023
FauxFrench my man, is it posible to amplifier works same with and without both operacional amplifier?
Old Yesterday, 09:03 PM   #11354
If one TPA3116 amplifier chip is defect, it is possible to remove that chip and the other chip should work again. The last test I proposed aimed at finding out if one TPA3116 chip is defect.
If it is your sub-channel that is defect, the stereo channel may play on. If it is the stereo channel that is defect, the sub-channel on its own is less fun (mono and mainly bass).
A problem is that you measured 2K on all pins but there are still high currents running so we do still not know where the defect is.
Old Yesterday, 10:07 PM   #11355
When I turn treble almost on max and volume almost on max then stop breaking sound and LED on board start turning off because of low power. That's all happening on 6V power supply.
When I just a little bit turn down treble or volume then start breaking sound again.
Old Yesterday, 11:36 PM   #11356
Douglas Blake is offline Douglas Blake  Canada
Douglas Blake's Avatar
On 6 volts the amp which still has gain set for 24volts will start clipping with almost no input. Check the Fualt pin... I'll bet it's bouncing on and off like crazy.
Everything works perfectly until you decide to show it to someone else.
Beginning lessons in electronics at... All About Circuits
TPA3116D2 AmpHide this!Advertise here!
FS- Twisted Pear Buffalo 32S Board & System New & Unused secretriches Swap Meet 1 10th August 2009 03:17 PM
Modify & build out (2) Western Electric 300B / 2A3 Hammond monoblock amps & UTC LS-5 quality sound Tubes / Valves 0 9th May 2009 04:59 PM
Krell KSA 80 bias & dc offset check & adjust procedure Clouseaupte Solid State 3 9th August 2007 10:39 AM
DIY-AMP <ZAS> Low THD & IM high bandwith murphy Solid State 18 30th December 2005 11:28 AM
Copyright ©1999-2019 diyAudio
