RB-TA2022 ref design any good
Thread Tools
Old 13th August 2012, 07:19 PM   #11
sweetperfume is offline sweetperfume  India
Originally Posted by Kjeldsen View Post
I can make a good deal on a RB-TA2022 version 3.1 6 channel amp with 1000 watt audio SMPS for 100$. But is this design good, or is there anything I should be aware of.
Most important is that it's stable and noise free, and it should af good sound (in know it have good sound so it more about how stable that design is)
try out TDA8920...i designed a pcb of it and doing well with it...it is fully protected...and will not require any external protection scheme
Old 13th August 2012, 09:01 PM   #12
Kjeldsen is offline Kjeldsen  Denmark
I have two TDA8950th already
Old 13th August 2012, 09:07 PM   #13
then u must be scoring 300 watts out of it....so why are u in need of other amps
Old 14th August 2012, 04:38 AM   #14
Mine are stereo, and around 90 watt 8 ohm. I fried the first two modules. Played well a couple of month, and then died. I didn't make proper connection between groundplane and heatsink. I have sparemodules, but I need better tools to cut the 5 holes to mount heatsink. The shall be within 0,2 mm and that is hard only using hand tools.
The Tripath I can have up and running in no time, and it's also just for fun, and because I can't say no to a bargain.
I also have NAD 3100 and 3300 on stock
Old 14th August 2012, 05:43 PM   #15
ok,,,you might be using an smd type....try a dip thru package....anyways ur choice it is....but i can starve hard on 8 ohms if u require 90 watts...would be quite sufficient
Old 14th August 2012, 05:57 PM   #16
It's from connexelectronic and smd type. I don't play loud and will build OB with four 10 inch peerless woofers in each speaker, so I will not need 1000 watt. Right now I play on 86 dB speaker with 10 watts, and that fine most of the time. Only material with lots of dynamic headroom requires more than 10 watt
Old 14th August 2012, 06:54 PM   #17
gr8...have fun
  Reply to this post
RB-TA2022 ref design any goodHide this!Advertise here!
Thread Tools
About TA2022 design designers LJM ljm_ljm Class D 48 15th April 2020 01:53 PM
Is this a good design? wildswan Solid State 20 23rd May 2006 10:15 AM
Good design? icebear Tubes / Valves 1 30th September 2004 12:44 PM
Pioneer TS-W304C- anyone have good design for it? and is it good for home sub? XteveX Multi-Way 7 28th April 2004 04:05 AM
Good design practice Morrist Solid State 25 7th February 2004 03:12 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
