Ultra Simple Class D
Old 10th August 2020, 06:34 AM   #621
stewin is offline stewin  Kenya
It can support up to 2ohms stable at +/- 49vlts , just increase the inductor to 35uh
Old 10th August 2020, 06:50 AM   #622
Hi all classd family !
I have a question to you all . If I change c10 from 0.47uf to about 10uf , what is the downside? And will the low frequency improve to drop low to about 10hz ??
Old 11th August 2020, 04:49 PM   #623
sweetperfume is offline sweetperfume  India
I don't think it will do any difference in lower frequency response. But it surely will hurt frequencies above 1khz. I might be wrong.
Old 11th August 2020, 04:52 PM   #624
I tested with 33uh. But only change is tgat i used 1m instead of 10m on pin 2 to 1 of tl074. Will that hurt efficiency that much?. And did you do resistor load testing? What efficiency did you get?
Old 12th August 2020, 01:11 AM   #625
yes thanks ,i tried 22uf and no noticeable change on low frequency
Old 12th August 2020, 01:14 AM   #626
use all parts exact as at the schematic i told you, that is the 10m should remain 10mega . the inductance that is the one i saw has a significance change when increased. by the way what type of inductor are you using?
Old 12th August 2020, 03:05 AM   #627
I used both micrometals -2 & sendust 60 material.
Old 12th August 2020, 03:07 AM   #628
  Reply to this post
Ultra Simple Class DHide this!Advertise here!
FETish: ultra-simple transconductance amp Mr Evil Solid State 38 13th May 2009 11:07 AM
The "Freebird" ultra clean ultra simple preamp design Russ White Chip Amps 87 11th August 2008 09:28 AM
ultra simple distortion effect apunker Instruments and Amps 14 22nd February 2005 06:04 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
