ICEpower 50asx2 modules
Old 12th November 2016, 05:03 PM   #81
Rizla is offline Rizla
I also found this from Jensrasmussen here on this forum in another thread :
For BTL operation you need to generate a balanced signal (one is inverted of the other) and connect this to the input (P102 pin 5 & 8).
Output is between pin 1 and 4 of the output connector (P101) (BTL only)
Remember to pull BLT sync pin low (to gnd) .... (P102 pin 1)
I hope this helps
Warm Regards
Jens
Old 13th November 2016, 09:40 PM   #82
incognito73 is offline incognito73  United Kingdom
Thanks for that! Still a bit confusing and pin-outs from the above don't match the 50ASX2 SE layout.Are those instructions for 125asx BTL mode?
Old 14th November 2016, 10:00 AM   #83
125asx is easily bridgeable without extra parts as i understand, the 50asx is not.
Do i understand it correctly?
Old 14th November 2016, 10:27 AM   #84
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Yes. The 125ASX (and 250ASX) is configurable by the user in either SE or BTL-mode. The 50ASX is sold factory-configured in either SE or BTL-version.
/U.
DIY projects blog
Old 14th November 2016, 12:26 PM   #85
/U.
Yes.
Have you had any success in turning the 50ASX in BTL mode, or know anything more about it?
Old 14th November 2016, 06:50 PM   #86
Nisbeth's Avatar
Only what I posted in post #75
/U.
DIY projects blog
Old 14th November 2016, 07:45 PM   #87
Well yeah, I don't mind re-soldering the jumper pin ... but just wondering if anything else needs to be done, apart from connecting speakers to P104.
Old 5th December 2016, 09:02 PM   #88
Nisbeth's Avatar
Old(ish) thread, but FWIW I've converted an SE module to BTL by simply moving the jumper and I believe it works.
Originally Posted by myself
I haven’t actually measured anything (not sure what to measure to be honest) but I get clean audio out on the BTL speaker connector (P104) and a very loud buzzing noise on the other output, so at least it isn’t running stereo anymore. No guarantees on anything yet though, but it’s definitely promising.
If there is a way to measure this (maybe the voltage gain) then let me know and I'll see if I can give it a go
/U.
DIY projects blog
Old 5th December 2016, 09:43 PM   #89
/U.
Sounds good. What you did was soldering as you described in post #75?
I have 20pcs of the 50ASX2SE lying here brand new
Old 5th December 2016, 10:41 PM   #90
Nisbeth's Avatar
Yes, move the jumper to the BTL-position and then connect the amp as shown in the data sheet (p. 22 in my version).
EDIT: You'll need either a balanced source or a phase splitter** to make this work with an SE source.
**Can be a transformer, a DRV134/THAT1646 type driver as I've used or an opamp-based circuit similar to what is shown in the designer's manual.
Then you wouldn't mind trying with a module or two to see if you can replicate my results, would you?
/U.
DIY projects blog
ICEpower 50asx2 modulesHide this!Advertise here!
Icepower Modules spchu Class D 15 23rd May 2011 10:24 PM
ICEPower modules for sale Alfetta87 Swap Meet 24 10th September 2010 05:14 PM
IcePower modules w/ wiring kit csuflyboy Swap Meet 5 14th November 2009 08:03 PM
Need one ICEpower 200ASC modules thim Swap Meet 1 14th February 2009 03:48 AM
Copyright ©1999-2019 diyAudio
