Boombox Battery
Boombox Battery
Old 3rd October 2011, 12:30 PM   #21
Buckapound is offline Buckapound  United States
I've had a really good experience with a LiFePo type. Better energy density than a SLA for the size and weight, good output voltage and very rapid charging (less than half an hour with the charger I have). Also, that type has a bit lower energy density when new, but over its lifetime that is supposed to remain fairly constant. Other lithium cells output less voltage over time, and have much shorter lives. That is why they are being adopted for electric bikes and other uses.
Here's the one I have:
LiFePO4 Belt Bag Bike Battery: 12.8V 6.6Ah (84Wh, 14A rate) + Fast Smart Charger
--Buckapound
Old 3rd October 2011, 01:12 PM   #22
fraction is offline fraction
Originally Posted by Saturnus View Post
It won't output as much power. The difference is only about 10%, so not really audible. However if you compare to a "12V" LiFePO4 battery which average 12.8V the difference is a audible 25%.
Cheers. Now to source some cheap and easy to use 12.8v lipos all packaged up in one unit, with charger.
Old 3rd October 2011, 01:16 PM   #23
Hang on, all the lipos I can see are 11.1 or 14.8v. Will tripath TA2020 amps take the 14.8v ones?
ah, I see the ones you mean now, 12.8v: http://www.ebay.co.uk/itm/FireFox-12...#ht_1948wt_902
Old 18th October 2011, 06:10 AM   #24
Motsey is offline Motsey
I have a 12v 9Ah SLA battery and was wondering if THIS charger would be ok to charge it?
Old 18th October 2011, 08:21 AM   #25
yup, but it will take ages to fully charge. Bargain price imo, compared to the others I've seen.
Old 18th October 2011, 08:25 AM   #26
My question is this:
On those blue li-ions there's an in socket and an out plug for 12v. Can I charge and use the battery at the same time?
Old 2nd December 2011, 04:38 AM   #27
bnhoang228 is offline bnhoang228  United States
So which one did you end up getting the Li-ion 9800MAH (New 12V Portable 9800mAh Li-ion Super Rechargeable Battery Pack | eBay) or the SLA 7AH?
I'm also building a boombox using the TA2020+ Amp. What sort of battery life am I looking at with either one?
Old 2nd December 2011, 02:26 PM   #28
PressureFM is offline PressureFM  Denmark
PressureFM's Avatar
Yeah, that battery is only 11.1V 6200mAh.
Old 2nd December 2011, 10:29 PM   #29
SLA it is!
Boombox BatteryHide this!Advertise here!
DIY boombox Scarbwill Class D 1 8th September 2011 04:31 PM
Big Boombox Cal Weldon Multi-Way 45 23rd May 2011 03:53 AM
Boombox no.2! :D Zenolijo Class D 24 7th April 2011 08:00 AM
Boombox in a car ashhegde Car Audio 2 11th June 2010 04:38 AM
Battery Charger for 15V Li-ION Battery Pack ??? Jan Dupont Parts 2 11th April 2009 03:18 PM
Copyright ©1999-2019 diyAudio
