Class D Amp with LM566, LM393 and 2XIRF530
Зачем вы используете BD139/140? Они низкочастотные, а так же IR2110 более чем достаточно. Вы делаете это зря.
i use 2sa1020 and 2sc2655 , when using ir chip direct without a buffer , the ir2110 gets hot
thanks manoj . noted
below the measurement of this topology but in russian vvvvvv
  • forum.cxem.net 100_2_.pdf
Chingy I know is been a long time, did the power supply works well? I'm doing some cosmetic fix to the layout let me know if the PSU did work well from post #771 :)
hi all , i am finishing my layout based on tl071 will post development and more pictures as i continue , .
comments and ideas are highly welcomed and appreciated
hi all just completed the layout , now its just developing the board :D:D
the files are below have fun all
  • gtY apex tl071 74AC00 IR2110.zip
  • gtY tl071 74AC00 IR2110 ver 2.0 bottom pcb.pdf
  • gtY tl071 74AC00 IR2110 ver 2.0 components.pdf
  • gtY tl071 74AC00 IR2110 ver 2.0 schematic .pdf
  • gtY tl071 74AC00 IR2110 ver 2.0 top pcb.pdf
