ucd 25 watts to 1200 watts using 2 mosfets
Old 8th July 2020, 08:01 PM   #4811
norazmi is offline norazmi  Malaysia
Stewin for op amp as comparator class D or discrete i suggest the solution to make it always oscillating by putting power resistor 50 ohm 50 watt, so that amp will never failed because its always having load at output.
Old 9th July 2020, 06:23 AM   #4812
this is the video stewin , evidence for you i can connect speaker and disconnect speaker at any thime no problem at all
Video ::::: YouTube
Old 9th July 2020, 11:23 AM   #4813
stewin is offline stewin  Kenya
hi norazmi thanks for the reply , please share your schematic and what voltage did you use ?
Old 14th July 2020, 02:54 AM   #4814
ive use my own schema stewin and because its for production i cannot shared it yet
Old 14th July 2020, 02:29 PM   #4815
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
Default Si2844
Small experiment with Si2844 gate driver ic
"It's Better to try and fail than to never know and always wonder"
Old 20th July 2020, 11:59 AM   #4816
odnaizutra is offline odnaizutra  Guyana
very nice!!
Old 9th August 2020, 01:58 AM   #4817
Default IGBT DCLASS
Hello
greetings to all the Dclass gurus the IGBT in the data sheet is obsolete
can anyone help me to find a similar or better igbt .
warm regards
Andrew
Old 9th August 2020, 05:58 PM   #4818
Parag99 is offline Parag99
Use FGH60N6S2
  Reply to this post
ucd 25 watts to 1200 watts using 2 mosfetsHide this!Advertise here!
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. renjiish Solid State 97 21st November 2018 01:51 PM
Decibel Watts VS Watts ? fivestring Solid State 11 1st April 2009 01:08 PM
AMP1-B: why only 25 watts @8ohms? theAnonymous1 Class D 10 15th August 2005 06:55 PM
Sound quality of amps at 0.3 watts vs @ typical 5 watts rick57 Solid State 2 26th March 2005 06:25 AM
Need 2 watts Vivek Everything Else 4 17th July 2003 08:29 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
