Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Class D Switching Power Amplifiers and Power D/A conversion |
#4781 | |
and load is normal 4ohms or 8ohms also the signal was too low and no much power was being required from the amps . there will be a faint hissing sound , then bang ![]() ![]() ![]() ![]() the only multi channel class d which stood the test of time without issues was sigma delta hifi tlo74 classd 200watts . i did it with single power supply smps supplying 5 channels and dual power supply smps supplying 5 channels and it did not misbehave or fail for no reason like the above high voltage class d . maxx voltage i have ever used successfully on class d 200wt was +/-49volts. Last edited by stewin; 7th November 2019 at 07:28 AM. |
#4782 | |
I think for help you should provide schematics from failed amps How about counterfeit semiconductor devices in your design ? Are you shure you get true genuine parts ? Often when amps fail in PRO design you have fakes I had bad frustration experience 2012/2013 I have make UCD IR2110 / CD4049 in 2012/2013, amp fail, smell and I give up .....June 2013 I travel Thailand for Holiday and find in Bangkok Electronic City Banmore same circuit IR2110 CD4049 / CD4070 PCB assembled I want to know it yet, have buy it and test later in Hotel appartment, everything work never fail with 90 V DC Check fake components |
#4783 | |
https://www.infineon.com/dgdl/Infine...53559b1bcc115c regards |
#4784 |
For hiss noise you can add input buffer like mine. Add cap bypass as marked as below picture. If buffer already there just add the caps.
#4785 |
you must be German: Throttle=Drossel(klappe), but here you meant a choke (inductor)
#4786 |
Hello to all! Sorry for my English. The problem of connecting several class D amplifiers (UcD) to a single power source is solved simply, it is necessary to power each amplifier plus power and minus power through separate diodes (for example, MBR30200CT). Thus, I connected four channels from one source and everything works fine. Sincerely, Boris B.
#4787 | |
So by bypassing this leaked frequency will kill the hissing sound. |
#4788 | |
Thread | Thread Starter | Forum | Replies | Last Post |
Philips 40/25/15 watts amplifier with Universal preamplifier circuit. | renjiish | Solid State | 97 | 21st November 2018 02:51 PM |
Decibel Watts VS Watts ? | fivestring | Solid State | 11 | 1st April 2009 02:08 PM |
AMP1-B: why only 25 watts @8ohms? | theAnonymous1 | Class D | 10 | 15th August 2005 07:55 PM |
Sound quality of amps at 0.3 watts vs @ typical 5 watts | rick57 | Solid State | 2 | 26th March 2005 07:25 AM |
Need 2 watts | Vivek | Everything Else | 4 | 17th July 2003 09:29 AM |
New To Site? | Need Help? |
