The Boominator - another stab at the ultimate party machine
Old 1st September 2018, 01:10 PM   #6691
lutkeveld is offline lutkeveld
LM3886 is a great amp, but the TPA3118/TPA3116 is a better alternative for portable builds due to its lower power consumption. Lots of modules readily available on ebay.
Old 3rd September 2018, 01:38 AM   #6692
Steffenland is offline Steffenland
I dont rly care about power consumption as this thing will be plugged in most of the time, if I can manage to get 3 hours out of it I will be happy. I will spend a bit time on the carpentry here and I want to fill it with some nice hardware, but I will need someone to help me out with a shopping list so I know where to start.
Old 3rd September 2018, 05:59 AM   #6693
Nenola is offline Nenola  Finland
Ok, then the LM3886. But I suggest that you create your own topic for this... because it doesn't have much to do with Boominator, or class D
Old 10th September 2018, 11:16 PM   #6694
REIER is offline REIER
So I have been wondering about something for some time now. The boominators dipole design boost low end performance, and gives some extra sensitivity due to magnet to magnet construction. But what if I only need the boominator to play from 200/250 hz and upwards? Can I get away with only one side and half the volume? What am I missing here?
The reason for this question is that I am trying to build a really compact PA system. And I am REALLY satisfied with the boominators performance. The more I listen to them, the more I love them. This summer I built 2 tham15s, and together with to halfinator boxes, we hosted a forest party for 110 people, and everyone was just baffled by the sound coming from those small boxes. But it was was to much work to carry this sound system 2 kilometers in to the forest. So now I am planning on making a smaller build, with some smaller subwoofers (for smaller parties yes), and back to my question. Can I chop off the other side of the boominator next time I build one if I adjust the xover accordingly?
Here's a picture of the project.
Old 12th September 2018, 07:05 AM   #6695
horst303 is offline horst303  Australia
Attachment 702745
a little confused, you find the boominator too big, but then in your picture you suggest these massive subwoofers?
But ignoring that issue, yes you can build anything you like, the thing about the dipole configuration is that it is the most compact way to mount two woofers and benefit from doubling the surface area and halving the impedance, and that's it, and that's not bad because that's 3dB each.
As far as the benefit of having the magnets interact with each other and bump up the sensitivity, I'm not really convinced.
Motor design is a pretty involved process and optimized for the voice coil and magnet gap, shoving another magnet at the back is pretty un-mathematical, who is to say that you're not making things worse? well those who have measure this, and as far as I know, nobody has. Gut instinct (well inverse square law basically) tells me that it probably doesn't matter either way.
Old 28th October 2018, 12:02 PM   #6696
JensToft91 is offline JensToft91
Default Boominator maybe lacking bass
Hello,
I've taken my old boominator back to the workbench to do some measurements. I've always thought my boominator was missing some low-end repsonse. I did check the phase and wiring and it's correct.
I have attached a near-field measurement of the woofer.
Do you have a similar measurement i can compare to?
Ive done a leak-test by taping the bass-reflex with a hose through. I've found that the drivers are not air-tight, as i can "Suck" a plastic bag to the woofers. Is this normal?
Jens
Old 28th October 2018, 12:04 PM   #6697
Test: I've tried posting a reply, but it doesn't show
Old 28th October 2018, 12:10 PM   #6698
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
You were under moderation like all new users. After a few more posts you'll be released into freedom.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 28th October 2018, 12:37 PM   #6699
Yea, I didn't get the warning before i made the quick-reply
Explanation: When i posted from "Advanced" it didn't show the "moderator approvement message". It just went back to "Class D" without warning..
Thanks for approving :-)
Old 28th October 2018, 12:51 PM   #6700
pinkmouse's Avatar
No probs!
The Boominator - another stab at the ultimate party machineHide this!Advertise here!
