This is not just another gainclone
I fired up my Gainclone yesterday.Everything seems to be allright.I have three diffrent pairs of speakers.One of them are Altec 891A,two way studio monitors.When I hooked them up they started cracking.They play the music but crack.Only when listened very silent they don't.I was investigating what is happening and figured that the couse was a speaker cable (quite expensive one,figh capacity-about 1nF per meter).Exchanged cable and everything works fine.It happens only with Altec's.Other speakers don't crack with this cable.Also when I unplug one of the Altecs from GC there is no cracking and I can listen as loud as I want.Is it possible that GC is so sensitive? But why there is no cracking when only one speaker is connected.There is no diffrance which channel and which speaker.
I used 800VA ,2*19VAC tr.,25A single bridge,2,2uF coupling cap ,220K feedback resistor.Also I have DIY Aleph P preamp so instead of 50K pot I put 47K resistor to ground.
Dc offset is about 50mV ,same in both channels.
Do You have any idea why does it crack?
Bartek
Matttcattt said:
On your site you mention building GC for a car amp. But what do you do about voltage regulation?
Or do you use the simple 0-14.4 V voltage swing of a car? In that case the National LM chips would not work because they must have a +- supply, whereas the OPA chips will work (but I think that you use them).
But with 0-14.4 V you waste a lot of potential of these amp chips, since most of them are designed to work up to 80 V voltage swing...
And how will you stabilize the voltage? Simply with filter caps? I do not think that the solution will be sufficient...
If building a chip amp for a car I would stick to those chips now commonly used inside car stereo units... and not those for home use...
Bye,
Arndt
diyAudio Senior Member
Joined 2002
Strange...I am using IE6.0 SP1 + a whole raft of sandbag updates on Win2K and have no problem whatsoever.
If you guys want that page in a different format I can convert it to *.doc (MS Office 2000) or *.PDF (you'll need Acrobat Reader for that, free at adobe.com).
Just send me a e-mail through the forum and I'll mail it to you.
Cheers,;)
Your amp oscillates, IMHO.
Place Zobel network on amp output terminals.
Joined 2002
At a nanoF/m this to be expected....can't imagine any half sane cable designer putting such a crazy cable onto the market.
A well designed OPT coupled tube amp would drive that without going belly up but that's about it.
It'll still be on the brink of stability and I doubt it would solve it entirely...beter than nothing, I agree.
Cheers,;)
