How big of an amp can I make with this?
at 30-0-30 the supply voltage will be pretty high so you will probably need to run into 8 ohm loads unless you parallel some chips. If you went with straight LM3886 you should be able to get 6x60W into 8 ohms, give or take. So 360W of output power. If you wanted one large amp then you'd need to do 4xLM3886 bridge/parallel (BPA) or a 6 chip version, 3 in parallel on each side of the bridge. Just some ideas. Power output is a guesstimation.
-SL
30-0-30Vac would be a good start for a 4ohm amplifier.
BUT
It would better suit a discrete design with that sort of voltage.
Parallel pairs or triplets of chipamps starts getting beyond the simple intention for using a chipamp.
working backwards from your transformer rating
670VA supports about 420W of output power.
This could be 210W+210W into 4ohm
but this needs 35-0-35Vac to get the necessary DCrail voltage.
or
140W+140W+140W into 4ohm. That is about perfect for 4ohm drivers and running on +-44Vdc
Ah! a three channel front of house amp for a 5.1 system.
This is simple
http://www.diyaudio.com/forums/attachment.php?s=&postid=624266&stamp=1114046322
http://www.diyaudio.com/forums/attachment.php?s=&postid=626955&stamp=1114369981
This post will explain implementation
http://www.diyaudio.com/forums/showthread.php?s=&threadid=38828&perpage=10&highlight=&pagenumber=1
Parallel as many as you like. I went up to four with good results.
You will have to find a really high current regulator. There are people on this site, who reported using +/-42 volts without problems
