Chip Amp Photo Gallery
Chip Amp Photo Gallery Please consider donating to help us continue to serve you.
Old 24th May 2018, 01:48 PM   #3161
ukhopeful is offline ukhopeful  United Kingdom
Default Pre and power amp build
My first build and first attempt at SMD!
I used amp boards from Tom Christiansen (Neurochrome.com)
Old 24th May 2018, 11:00 PM   #3162
troystg is online now troystg  United States
troystg's Avatar
I'm sure that sounds fantastic!
Is that a soft start in front of the smps in the amp? (Front circuit wise)
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 25th May 2018, 08:27 AM   #3163
No, it's one of these
ON-OFF modul
There's one in the preamp too. In the preamp it's used to control the volume pot motor and IR remote control. In the power amp it's just used to receive a trigger signal from the preamp board so that I can power both amps from the switch (or remote) on the preamp.
Old 27th May 2018, 05:04 PM   #3164
Cowmans is offline Cowmans  Belgium
Beautiful build! Modushop enclosures?
Old 30th May 2018, 09:04 AM   #3165
Thanks. Yes, a SlimLine and a Dissipante. I sent the panels to Schaeffer for processing.
Old 5th June 2018, 03:08 PM   #3166
NealJ is offline NealJ  United Kingdom
This is my LM3886. I just started with electronics this year. I've made a couple of CMoy headphone amps, the O2 headphone amp and the ACA. I love how you can go from no knowledge whatsover to building an amp you're proud of, and enjoy listening to, in a short period of time by using this site and others.
Old 5th June 2018, 03:18 PM   #3167
willsw is offline willsw  United States
Nice build as one of your first. You'll never have to worry about heat dissipation with that case.
I would route the output wire around the sides of the transformer. A toroidal transformer is noisiest above and below.
Old 5th June 2018, 03:44 PM   #3168
Thanks, I realise the heatsinks are over the top but I like the look and it fitted perfectly in my rack.
I didn't realise transformers had a direction to their noise, thanks for the tip.
Old 5th June 2018, 09:47 PM   #3169
Reddo is offline Reddo  Netherlands
My first (and finished) LM3886 build, using 2 x Modulus 86 and power 86 from Neurochrome in a dissipante chassis with 300 VA transformer, Allo stepped attenuator and a Lorlin input selector.
Old 5th June 2018, 11:14 PM   #3170
mhouston is offline mhouston  Australia
mhouston's Avatar
Pro looking build.
Chip Amp Photo GalleryHide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
