Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Chip Amps Amplifiers based on integrated circuits |
Thread Tools |
#1511 |
Zak, you either need a tripod or less coffee.
Kevin |
#1512 |
My Version of Gainclone
#1513 |
another pix..
#1514 |
Some more pix... Just brief Description, This is a regulated version gainclone with a supply of around +-28v, I used Peter Daniel's pcb's, with the Zobel network connected and ci used. Its connected to a DIY speaker as well, a backloaded horn using Fostex FE126en. This is my first DIY projects and I'm loving it...The sound? well.. its fantastic!!
#1515 |
Nicely done reytnz !
#1516 |
Thank you! korben69
#1517 |
Did you soldered the resistors to the stepped attenuator by yourself?
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN! |
#1518 |
Yup, I've just followed the instructions that comes with it. I lay all the resistors on a piece of paper and label each value making sure I've got the right one to go to the right sw. terminal. I made sure I've got it in one go, without overcooking the contacts.
#1519 |
R.I.P.
I see many exposed conductive parts.
How have you connected them to the Safety Earth, when there is no enclosing metal chassis?
regards Andrew T. |
#1520 | |
![]() With kind regards, Bas |
Thread Tools | |
New To Site? | Need Help? |
