My BGT-Clone
My BGT-Clone
Thread Tools
Old 28th February 2005, 08:16 PM   #1
Gcollier is offline Gcollier  Canada
Talking My BGT-Clone
Well after reading so many posts here and getting inspired by everyones beautiful work, I decided to post my own clone. It is nothing fancy really, a dual LM3875 with panasonic 1% metal film resistors, and 1000uF FC caps. The transformer is a 160VA from Plitron, which has no trouble keeping up with the amps at higher than tolerable levels. The boards are my own version of BrianGT's LM3875's (hence the BGT-Clone).
The chassis is simply 1/2" baltic birch plywood with solid 3/4" black walnut sides. For a heatsink I used a piece of 1.5" aluminum angle attached to a cutdown heatsink from a long dead amp. The Faceplate is also cut down from the same old amp, but has been polished with a lot of elbow grease
The sound is very good, especially when compared to the other mass produced garbage that own/have owned. When I gave it the first audition my wife actually said "Is all that sound coming from just those two speakers!?" The midrange is excellent, very detailed, and the bass is firm and punchy, but not overly boomy...nice! I am in the works of replacing this with a parallel LM4780 5 channel HT amp This little guy may go to my office with a small...but efficient...set of bookshelf speakers.
If you take something apart and put it back together again enough times, eventually you will have two of them.
Old 28th February 2005, 08:18 PM   #2
Default And the other views
The Front
Old 28th February 2005, 08:19 PM   #3
Default The Back
The Back
Old 28th February 2005, 08:20 PM   #4
Default Amplifier Channel
Here is the Left channel. These boards were produced using BrianGT's LM3875 design..Nice work Brian, Peter and the rest who contributed to this design!
  Reply to this post
My BGT-CloneHide this!Advertise here!
Thread Tools
F1 Clone DIY PCB suds Group Buys 2 8th January 2009 10:50 AM
My F3 Clone 04dgmsilv Pass Labs 11 31st August 2008 12:59 PM
clone AN/K ccopp Multi-Way 0 9th July 2006 09:24 AM
Question regarding ProAc 2.5 Clone and Tempo 2 Clone zoooh Multi-Way 5 11th March 2003 09:19 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
