Design from scratch (LM3886)
Old 25th August 2004, 12:43 PM   #11
carlmart is offline carlmart  Brazil
Originally posted by VEC7OR
Do I miss something really important ? Ugh, do I need a resistor between the ground and the non-inverting input or I just connect non-inverting to the ground ?
Use some resistance or you will have offset.
You can try from 220K to 10K and see which works better for sound. Also listen to it with and without parallel cap on resistor.
Carlos
Old 25th August 2004, 01:18 PM   #12
Ouroboros is offline Ouroboros  England
Ouroboros's Avatar
Your dc impedance from the - input to ground is 220k, (The input is capacitor-coupled so has an infinite dc impedance. To get the best thermal tracking of the dc offset you could put a 220k resistor from the + input to ground to match the dc impedance on both inputs.
My view is that 220k will increase the noise. Try it with a direct short from + to ground as you have at the moment. If the dc offset voltage is OK then you could leave it as it is.
(The other option is to put a 220k resistor, but bypassed with a capacitor.)
Old 27th August 2004, 10:37 AM   #13
VEC7OR is offline VEC7OR  Lithuania
VEC7OR's Avatar
Hm I think thats about it. Any suggestions ?
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots.
Old 27th August 2004, 10:50 AM   #14
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
The 220k at the pos input will generate a lot of noise. You should decouple it.
Jan Didden
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio articles - SilentSwitcher - Treg high voltage regulator - High-voltage delay unit
Old 27th August 2004, 11:14 AM   #15
VEC7OR's Avatar
10nF ceramic will do ?
Old 27th August 2004, 11:36 AM   #16
VEC7OR's Avatar
PSU schematic.
Old 22nd September 2004, 07:41 PM   #17
VEC7OR's Avatar
The PCB, I'll use the laser printer and steam iron to transfer it to PCB, then peel the paper after its soaked in water and then I'll etch it
Old 22nd September 2004, 07:45 PM   #18
VEC7OR's Avatar
doh teh file
Old 22nd September 2004, 08:23 PM   #19
djQUAN is offline djQUAN  Philippines
Send a message via MSN to djQUAN Send a message via Yahoo to djQUAN
I find it easier to use a permanent marker to draw the foil patterns. well, that's my choice.
Old 22nd September 2004, 10:00 PM   #20
VEC7OR's Avatar
epp, tried that too, tried drilling them, now wanna try this, maybe even I'll try resist coated boards, but thats later on some bigger boards.
Hm, I wonder how good I'll be ? will the toner hold good ?
Design from scratch (LM3886)Hide this!Advertise here!
lm3886 design pingu Chip Amps 15 7th June 2009 03:49 PM
yet another lm3886 design geekysuavo Chip Amps 0 31st July 2008 11:18 PM
My first "from scratch" design, SE KT88.......... cadaverdog Tubes / Valves 9 8th April 2008 07:39 AM
LM3886 : which design ? Volta Chip Amps 10 22nd April 2006 07:02 PM
How to design an amp from scratch... Bakmeel Solid State 1 26th March 2002 02:10 AM
Copyright ©1999-2019 diyAudio
