A totally unique portable speaker, or music box or boombox whatever u call it. There is no similar. It was my idea to name it Harley Davidson because, Its looks like a cool motorbike like a harley .. got me to name it. I used a bluetooth 5.0 receiver. I used 2 mono tpa 3116 amps, Passive tone filter and my own design vu-meter. 6mm MDF layers and 14mm hush contra front and back cover. This boombox is powered by a 16.8v 18amp li-on power supply.
I am also using 22v with step-up converter. Harley Davidson 5" 2 way stage 3 components speakers. They are driven at 2 ohms. At these values, I think it reaches +200w rms total output. Box design bass-reflex. As you can see, it consists of boxes. Its construction is in matrix structure. I don't think it has been used in this type of system before. I'm probably the first to use it. As you can see, it's a completely different device. In the next videos, I will listen to his original voice. That's all for now.
Harley Davidson - Bluetooth - Boombox - Custom - Diy - YouTube
