Amp outputs for LG 55um7000 (TV) internal speakers
Thread Tools
Old 12th April 2021, 05:42 PM   #31
OldDIY is offline OldDIY
I meant to be careful to avoid shorting the high frequency output through the parasitic capacitances of the transformer.
In each channel you have two high frequency PCM voltage outputs with a voice coil connected between them.
Old 3rd May 2021, 06:53 PM   #32
Фильтр для усилителя PAM8403
  Reply to this post
Amp outputs for LG 55um7000 (TV) internal speakersHide this!Advertise here!
Thread Tools
Question about internal TV speakers amp earworm Solid State 25 5th May 2020 09:59 PM
Stage Piano Internal Speakers Dr. ODD Instruments and Amps 3 19th January 2009 04:14 PM
Balanced outputs used as inverting & Non-inverting preamplier outputs gni Solid State 4 19th September 2008 03:25 AM
laptop internal speakers mrybczyn Multi-Way 1 25th May 2008 07:26 AM
What internal wiring to use for speakers? AJ Bertelson Multi-Way 3 17th May 2004 05:59 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
