Hardwired LM1875 from ALiexpress
Thread Tools
Old 20th February 2021, 06:26 AM   #31
ttan98 is offline ttan98  Australia
Thanks, everyone for contributing. I agree with some and disagree with others.
I don't have any more to add or contribute, hence I declare this thread closed.
Old 20th February 2021, 11:30 AM   #32
adason is offline adason  United States
adason's Avatar
Not until we say so...
Old 25th April 2021, 06:19 AM   #33
Default New Image
The unit I bought. See the hardwired LM1875, the image below.
I thought I will give you guys the update of the Hardwired LM1875 module I bought for 2 channels.
It arrived many weeks ago now I manage to put it together in a testbed. See the image below, it's for testing purposes only. If it sounds good I will put it in a proper case.
Comments:
1. Powered up with about 17Vac--0--17Vac. First up no problem and I can hear music.
2. Sound seems ok, so far no distortions for the time being no critical listening as yet, I bought to replace my Tube EL84 which generates about roughly the same power, 12-15Watts per channel.
3. I am using this amp to drive a tweeter or a low-powered full ranger in an active DSP x-over configuration.
4. Note that the coupling capacitor is a large red cap., and also the bypass cap both can be bypassed in another LM3886 chip amp. Because of the input Offset voltage, I will get an output offset whether it is acceptable I yet to find out.
5. After testing and listening I will come back to advise you whether it is worth buying. I won't give you a blow by blow updates.
Thanks for reading.
Old 25th April 2021, 06:36 AM   #34
EUVL is offline EUVL  Europe
It is worth buying just as a piece of electronic art.
Just appreciate the craftsmanship that goes into making something like this.
Patrick
xen-audio.com
Old 22nd July 2021, 07:51 AM   #35
Just completed my hardwired amp. just a little slack lately. Haven't evaluated the module for sound quality yet.
I thought you may like to see a few images, the power transformer is mounted in a separate box. The size of amp module in wooden box is about (W*H*D) is 16*7*13.5 in cm. Looks cute.
  Reply to this post
Hardwired LM1875 from ALiexpressHide this!Advertise here!
Thread Tools
Full range speakers hardwired into TV Jeff 777 Full Range 17 13th January 2013 07:59 PM
Hardwired X/O components on Cu-Clad PCB clm811 Multi-Way 4 31st July 2008 01:00 AM
Hardwired GC problem Sherman Chip Amps 5 13th May 2004 12:23 AM
Hardwired DAC incl. the DF1704 (SSOP) A 8 Digital Source 4 21st May 2003 08:23 AM
How should I build the Son Of Zen. Hardwired or using PCBs? Erik Johansson Pass Labs 15 1st July 2002 04:24 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
