Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Chip Amps Amplifiers based on integrated circuits |
Thread Tools |
#11 |
I have your SA2012 PCBs finished populated with their components too, the only reason I chose to use the ones I posted above is the extra pair of IRFPs that I hope it will give me the extra something for the use of the amp to drive pairs of 9" woofers.
#12 | |
What astx said.
Including keep the MosFets, forget Bipolars here, use driver IC as intended. Good luck with your project. Only point that worries me is: Quote:
![]() Those are 4 ohm woofers, so use them in series for 8 ohm per pair.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969. |
#13 |
Thanks JM, I'll go for a new trafo with dual 0-50VAC secondaries, as for the woofers they are in parallel and not 4Ohm each, speaker's impedance drops only down to 3.5/3.2Ohm @30 and 100Hz according to the graph.
![]() Last edited by giaspyr; Yesterday at 12:14 AM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Precision Matched Vishay IRFP240 IRFP9240 MOSFETs and IRFP240 MOSFETs | rhthatcher | Swap Meet | 0 | 1st January 2021 08:39 PM |
IRFP240&IRFP9240 power amplifier schematic | mos | Solid State | 31 | 26th June 2012 09:21 AM |
250W amp with IRFP240 & IRFP9240 | badboy6120 | Solid State | 9 | 1st August 2011 06:39 PM |
IRFP240+IRFP9240+LME49830+INA134+UPC1237 power amplifier | gxcnabin | Solid State | 17 | 12th February 2011 11:00 AM |
best price for irfp240 & irfp9240 in France | djdamix | Parts | 2 | 27th September 2004 12:53 PM |
New To Site? | Need Help? |
