Xmas Amp - Dibya's TDA7293 by Jhofland
Thread Tools
Old 15th October 2021, 07:53 AM   #781
jimk04 is offline jimk04  United Kingdom
Buttoned up and was playing last night...so it works! No real critical listening yet and we have no curtains at the moment as the window is being rebuilt so the room is a little lively right now.
Also a video I made of the Mark Johnson H9KPXG soft start
Mark Johnson H9KPXG soft start - YouTube
Salas DCG3, Ian Canada streamer, JLE 3255, Dibya Xmas TDA7293, Miro AD1862, diy XRK Ref Monitors. B&W DM14, Currently building Pass AB100, Wayne's BA18 and maybe F3
Old 15th October 2021, 02:47 PM   #782
turion64 is offline turion64  United States
Isn’t this why we love being DIYers? Building it with your own hands? A bit of architectural design…trusting the component designers…having the freedom to make alterations..and then seeing and hearing the fruits of our labors as well as that sense of accomplishment we get?
Bravo on your build jimk04!
Pete
Anyone who has never made a mistake has never tried anything new. - Albert Einstein
Old 15th October 2021, 05:41 PM   #783
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
That’s a nice looking amp! Congrats Jimk04
Old 26th October 2021, 02:05 AM   #784
Kokanee is offline Kokanee  Canada
Kokanee's Avatar
Hello Builders,
I had some time to work on the Xmas amp and some other components. I have attached a pic of the layout I would like for the construction. I am asking if anyone can see anything that looks out of place.
Thanks,
MM
Old 26th October 2021, 09:14 PM   #785
Got Foam?
xrk971's Avatar
Hi Myles,
You pretty much are using all existing space. The only thing I would try to do differently is to move the toroidal donut as far from amp module as possible. So against the front panel like how I have in sketch. Move the SFP farther away as well. The idea is keep 120vac mains as far from the low level input signal as possible. This will reduce noise pickup.
File Type: jpeg 144933A1-5659-4193-BFA5-D86E3459BD6E.jpeg (101.1 KB, 166 views)
Old 26th October 2021, 09:41 PM   #786
Kokanee's Avatar
Thanks X,
At one point, I had the X's parallel to the front panel, one in each corner of enclosure. I will put it back that way, and see if I can free up some space between them and the amp board.
I can also move the SFP to mount on the front panel.
Is your pic showing both transformers in one corner?. I think my enclosure would tip due to the weight of both X's.
MM
Old 26th October 2021, 11:25 PM   #787
Kokanee's Avatar
Hi X and other builders,
Please see pic below for updated layout for one channel. The other channel will mirror this layout. I think this is better than the one in post #784. I only have 12" of depth to play with.
The SFP will be mounted on the front panel between the transformer's.
One other question, I have applied thermal paste between the back of pad and heatsink. Was I supposed to apply paste to the back of the chip and the front of the insulator pad also?.
Thanks,
MM
Old 27th October 2021, 03:14 PM   #788
Got Foam?
xrk971's Avatar
I was lazy and only marked up half of the drawing.
Your new layout looks great.
Old 27th October 2021, 04:37 PM   #789
Kokanee's Avatar
Thanks X,
Do I need thermal paste between the back face of the transistor and the front face of the insulator?
I have paste between the insulator and the heat sink.
MM
Old 28th October 2021, 04:50 PM   #790
Got Foam?
xrk971's Avatar
If your insulator is a silicone pad, no. If you are using ceramic or mica insulator, then yes.
  Reply to this post
Xmas Amp - Dibya's TDA7293 by JhoflandHide this!Advertise here!
Thread Tools
Some Class A pcbs for sale designed by xrk971/AKSA/JPS64/Jhofland... Kokanee Swap Meet 9 19th April 2020 07:00 AM
A moment's thanks for jhofland legendre The Lounge 1 5th April 2020 06:21 PM
Unshure of class, but its the ultimate xmas amp FE3T Class D 8 14th December 2008 05:34 AM
Xmas Babyboom Guss The Lounge 2 25th December 2003 11:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
