Xmas Amp - Dibya's TDA7293 by Jhofland
Thread Tools
Old 11th October 2021, 09:55 PM   #771
DaveFred is offline DaveFred  Canada
These are the last pics, I swear...
Amp is done!
Some details of how I put it all together in the end,
Alps 10k volume pot was mounted at the rear of the amp near the inputs to make the signal path as short as possible and not cross too many wires.
I tried about 5 different signal wires and found most very difficult to work with.
The signal wire I settled on is Tensility International Corp pn#30-00346, Digikey has it.
The "standard" volume pot extension with bushing is kinda crappy, so I made my own with 6mm brass rod from Amazon along with a 6mm coupler and 6mm linear bearing from Aliexpress.
6mm Linear bearing from Aliexpress
6mm Coupler from Aliexpress
I wanted to have the switch at the front of the amp, but nice switches that are rated properly are hard to come by. I used Schurter Inc pn#1241.6821.1110000 which is rated for 12 amps at 250v.
To connect all the powers together I used Bud Industries pn#DMB-4770-CB breadboard which has holes big enough for the faston tabs to fit into. The faston tabs were jumped with a soldered large gauge solid core copper wire on the backside of the breadboard.
The power on lamp was an expensive 110v one, E-Switch pn#PVL14FWS16, but it was dumb dumb easy to install.
All bare stranded wires had a wire ferrule crimped over them before going into screw down blocks.
I think those are most of the little finishing details that I used for "assembling" the amp.
Thanks for everyone's help along the way!
Now for some critical listening,
David.
Old 11th October 2021, 11:30 PM   #772
Mark Tillotson is offline Mark Tillotson
I'm confused - you use a linear bearing with rotary motion?
Old 12th October 2021, 01:09 AM   #773
Yes, it's just balls, this one doesn't care if it rotates or slides.
Old 12th October 2021, 04:55 AM   #774
Dibya is offline Dibya
@ DaveFred that's looking really nice.
Old 12th October 2021, 08:17 PM   #775
xrk971 is offline xrk971  United States
Got Foam?
xrk971's Avatar
Nice work!
That’s a whole lot of work to connect all those things in a 3D puzzle.
The one reason I like integrated IEC with fuse drawer, rocker switch, and EMI filter. It handles a lot of the grunt work for mains stuff.
XRKaudio Store // Manufacturer’s Forum
Old 12th October 2021, 11:32 PM   #776
flamethrower1 is offline flamethrower1  United States
Nice build DaveFred
Old 13th October 2021, 05:51 PM   #777
jimk04 is offline jimk04  United Kingdom
Been off ill this week so far and whilst it has stopped me from doing my usual manual job it has given me time to finish my Xmas amp. Well I say finish it I've pretty much done it all. Boards were populated before hand.
Took me a loooong time as usual. I always seem to have too small a chassis and so packaging and routing becomes tricky. I'm not totally happy with the layout and wire runs but it is what it is for now.
Running a 29v trafo through CRC giving 39vdc.
Using Mark Johnson low voltage soft start thing.
Using some Aliexpress protection board.
Fired up without flames! Offset is about 5mv. Everything seems stable albeit sat idling with no load or input. Only issue I see is the protexr board runs 5v relays and the AC input level is giving the 7805 a hard time. ....I have one I got for class d pbtl so it has 4 relays....un common L and R grounds....runs at 12v. Can I use that?
Anyway hopefully tomorrow i can plug it all in.
Thanks to everyone for the advice in this thread and again to Peter (turion) for the boards he sent me many moons ago before I learnt how to buy my own from JLCPCB!
Salas DCG3, Ian Canada streamer, JLE 3255, Miro AD1862 diy XRK Ref Monitors. Currently building Pass AB100, Wayne's BA18
Old 13th October 2021, 08:43 PM   #778
Got Foam?
xrk971's Avatar
Nice work, Jimk04! Love those thick silicone insulated wires.
You don’t need a PBTL protection board but it doesn’t hurt. It just means the speaker out -ve is isolated from ground.
A lot of people are putting both amps on one side of a chassis even though they have two heatsinks.
Old 13th October 2021, 08:46 PM   #779
Got the silicone wire nod from yourself a while back...RC car wires! Good shout.
I realise it is a waste of a sink but for these boards I preffered the signal input wiring to be short so it meant setting the boards out thus.
Hopefully will get to hear it tomorrow.
I've just started reading the Alpha Nirvana thread!��
Old 14th October 2021, 12:27 AM   #780
Got Foam?
xrk971's Avatar
The Xmas amp pairs really well with the 10F/RS225 Fast speaker that you have. You’ll like it a lot.
Xmas Amp - Dibya's TDA7293 by JhoflandHide this!Advertise here!
Thread Tools
Some Class A pcbs for sale designed by xrk971/AKSA/JPS64/Jhofland... Kokanee Swap Meet 9 19th April 2020 06:00 AM
A moment's thanks for jhofland legendre The Lounge 1 5th April 2020 05:21 PM
Unshure of class, but its the ultimate xmas amp FE3T Class D 8 14th December 2008 04:34 AM
Xmas Babyboom Guss The Lounge 2 25th December 2003 10:06 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Resources saved on this page: MySQL 13.64%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
