Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Chip Amps Amplifiers based on integrated circuits |
Thread Tools |
#21 | |
Hi chris, I was not informed when I bought it. Yes there is a channel which has a higher gain. So if I understand correctly, we will have to buy resistors with good precision, and measured them to have the most equal gain on the 2 channels. Denis |
#22 |
partly yes...
because the gain must be the same over the complete frequency band, e.g. 20Hz to 20kz...ever mini deviation of voltage at amp 1 force to other amp "to be pushed". that´s why you should use a small resistor of 0,1R - 0,33 R. |
#23 |
Okay I understand a little more. The LM amp was plugged in fullrange on my speakers, I just changed the configuration, now it is plugged into the woofers cut to 900hz, the LM is superb in the low midrange, and double the bass is powerful and precise. The woofers are Wavecor.
The gain seems equal in the bass. I keep in mind about the adjustments. Denis |
#24 |
I installed the 2nd toric. I didn't expect him to be that big. It has 1 volt AC less on each outlet. Then it's time for listening tests.. ![]() Denis |
#25 |
Hi everyone,
I listened several times with the LM and its 2nd toric transformer. The sound is perfect, no imbalance between the two and it seems to me on all frequencies. The soundstage is precise and does not move. I will eventually measure with a mic and REW both channels. My new 3-way speakers that I have designed are quite linear and well balanced. The tone of the LM1875 DE Zero Zone mono cards is really to my taste, it is a tone that I would describe as smooth, but at the same time quite dynamic, the bass is powerful and articulate, the midrange is all spread out in the soundstage, and the highs and extreme highs have more presence and transparency than my other LM1875 in singles. I highly recommend it. Regarding the adjustment of bias resistors (or balancing), I could not touch anything. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Single supply LM1875 on a double supply pcb | iinself | Chip Amps | 32 | 8th February 2015 07:15 PM |
Double rail PSU, double ground rail connexion ? | youyoung21147 | Chip Amps | 5 | 6th November 2005 06:12 PM |
Help with hum small hum problem... | Guiness | Tubes / Valves | 10 | 5th May 2003 05:23 PM |
hum problem with LM1875 | JAZZ2250 | Solid State | 1 | 13th February 2003 07:42 PM |
New To Site? | Need Help? |
