I recently bought 2pcs LM3886 IC from
LM3886 IC - 68W High Performance Audio Power Amplifier IC buy online at Low Price in India - ElectronicsComp.com
They show LM3886T on the website. Then supply LM3886TF.
Further it is fake. When i put in circuit it blown my mains fuse & also track on PCB. Then I checked the 2nd piece along with one that was with me working.
Even the leads length was short.
So don't buy from this supplier. Be cautious.
Very bad response when made complaint.
I got dupped
Hi Palesha,
I placed order for 3 and transaction was done but then for 6 days no delivery so when I called them they said they are out of stock.
Now awaiting refund. 1650/- in the air.
I wish I had read your post earlier.
Hi Palesha,
use rs components in india
RS Components | Electronic, Electrical & Mechanical Components
you need large quantity use mouser.in but credit card shall do Visa
No stock at Mouser, RS, element14, Farnell in India last I checked.
Diyaudiocart has for 425 as of yesterday, listed, did not click to buy...
Indiamart has seller at 140, must be fake.
Or buy Keltron kit from Salcon, 1900 or so assembled with heat sink, stereo.
I bought a lm3886 and it blew as soon as I powered it up.
I started thinking it was fake.
I then had a good look at pcb to see if there was a short.
Lo and behold one of the front pins of the chip amp was shorting on the pcb chip amp back pads.
I removed the device and put in a new one sitting a little proud off the pcb and that worked fine.
Got some LM3886TF locally, checkout quality,are the original ICs or fakes
I had a bad exp with these guys also.
Purchased a 3 x 600 Mah bat from them cause the 200 mah 8 year old bat in my blue tooth headphone was only lasting 30 min.
Their bat. Which was twice the size and supposed to be 600 mah. Only lasts 10 min.
When I contacted them asking if I could at least return the extra 2 Which I had not even opened. I was told sorry we do not take back bats.
Avoid these guys like the plague.
If you want the right part I normally order form digikey or rs components. Or even shelf key. These are all trusted names. That will never let you down.
I was going to order the LM and TDA IC from them. But instead ordered it from vaspelectronics. Old man Vasp is honest about what he sells. Im very happy with what ever I got from him. Haven't tested it yet. But it looks good. And he stands by what he sells. If its not original he will tell you. He will also test each part before shipping.
Just ask him if its original or not and he will tell you. Whatever he sells he tests before shipping.
Pro
the issue with Mouser.in and Digikey.in is the shipping fee is ₹1200/- so for a order of two or three amp chips eg tda7293 it’s like 2 times the cost.
i prefer element14 or RsComponents as shipping is free
I
First image of single LM3886 is from DAC, second is comparison of DAC and USA purchase ($20 a pair) bought 4pairs and using one pair works 😍.
third is the LM1876 Texas sample.
the thing to see is DAC chips has a rub mark where the serial # is printed and laser etch is not as bright as the other two. Not used them yet but planning to test them in a different board. Currently using a composite amp LM3886 My Rev Ref A
have bought from DiyAudioCart but compared to my LM1876 TI Sample and LM3886 ( Micheal ) it doesn’t look good.No stock at Mouser, RS, element14, Farnell in India last I checked.
- Chip Amps
- Fake LM 3886 IC at Electronicscomp.com
