Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Chip Amps Amplifiers based on integrated circuits |
Thread Tools |
Hi hope someone can help my understanding here. I am repairing a Cambridge Audio A1 mk3 fitted with two tda1514a chip amps. The two rail fuses were blown so I powered up through a DIM bulb tester. It indicated a problem (bright 100w bulb). I removed the two chips and found one had significant low ohms between supply pins and others. The other channel did not have shorts. I put the suspected good chip back in circuit and powered up. All ok this time with current draw and fuses but I checked the dc offset voltage across the single channel speaker output. Bearing in mind only one chip in circuit which I didn’t think should matter, I am getting 2.3vdc at speaker terminal. I haven’t tried speakers yet but this doesn’t appear correct. Am I missing anything in my understanding or do you think the second chip has an issue also.
Many thanks Mark |
#2 |
Taken at face value your 2.3 volts shows a problem as there should always be minimal DC voltage present across the speaker output.
I'm assuming this is a DC coupled circuit running on split rails rather than a single rail design with output coupling cap in which case some voltage would be expected with no load present.
Installing and using LTspice IV. From beginner to advanced. |
#3 |
Hi and thanks for responding. Yes split rail as in the attached. My gut said that there was something wrong with the second chip despite not causing fuse blow itself. I have not connected speakers as precaution whilst everything checks out. One chip gone the second giving the 2+ Vdc at speaker terminals. Just wondered if there was anything peculiar about tda1514a which would show this. Very simple and tda1514a spec sheet states low output offset!!!
#4 |
That's a pretty standard circuit. Any DC offset should be very low and certainly under -/+ 50 mv DC.
What is odd is that failure of one chip is a common and expected scenario but one that should have zero impact on the other channel. As long as the supplies are correct the chip should produce a very low offset. It might be worth just connecting a dummy load to this channel and seeing if the offset remains. Even a 100 ohm resistor would suffice. On remote possibility is the chip is unstable with no load but if that were so then it would be bad design.
#5 |
Check C41. And the voltages on pin 1 and 9. Those should be zero. The TDA1514 is just a powerful opamp.
#6 |
Thanks I will try that. I have 2 chips on order but just trying to further my knowledge and understanding. I will try the 100R load. and retest/report back.
#7 |
OK thanks guys. C42 100uF checks out ok (101.2uf and Vloss 0.7% and esr 0.27Ohm)
Pin 1 Ov to gnd Pin 9 2.6v to gnd. Voltage across 1 and 9 2.6v When 100R load placed across speaker output, 2.6vdc remains ! |
#8 |
It would be worth just measuring the DC voltage on pin 1 which is the input. This should be zero.
#9 |
Yes pin 1 to gnd is 0v
#10 |
That only leaves the chip then really... or its oscillating and unstable and so skewing the reading a DVM shows, or...
If the unit has a hidden history then things like spillage or contamination from say a leaky cap could conceivably cause issues. It would have to be around the chip though. All a bit of a coincidence really, to have a definite fault like a zapped chip and to then also have a weird issue on the other channel.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
tda 7293 and tda 7294 help | sagarverma | Chip Amps | 85 | 22nd March 2013 09:15 PM |
tda 1514a 220 pf capacitor | asbn369 | Chip Amps | 1 | 19th August 2010 06:42 AM |
Tda 1305 & Tda 1302 | hifive | Digital Source | 1 | 10th April 2006 10:04 AM |
TDA 1514A not holding its own | RIC | Chip Amps | 23 | 30th September 2004 05:39 AM |
could John Audio re-desigh the Trace elliot TDA 1514A layout | RIC | Chip Amps | 1 | 27th December 2003 05:39 PM |
New To Site? | Need Help? |
