Tda 1514a help please
Thread Tools
Old 18th November 2020, 05:24 PM   #11
Gmarkw2 is offline Gmarkw2
Thanks so much for your help. Agree with the thinking. Board very clean and no other real clues. Voltage regs for smaller control op amps check out ok also. Have checked all electrolytics around the chip and found ok. Ah well I will await 2 new chips and get them in to try. I will report back for the benefit of others.
Old 18th November 2020, 05:34 PM   #12
Mooly's Avatar
You're welcome
The chip should obey all the classic rules applicable to an opamp... namely that the output will do whatever it takes to bring the voltage difference between the two inputs to 'zero'. Looking like the chip then at this point.
Old 26th November 2020, 09:00 PM   #13
2 new chips received and installed. Powered up through dim bulb rig. No current issues, output dc offset now down at a few millivolts per channel. Connected up to speakers and a lovely sound was had.
It pays to be questioning and cautious.
Thank you for the helping hand guys.
Mark
Old 27th November 2020, 07:02 AM   #14
Mooly's Avatar
that's good. Pleased to hear it was an easy fix in the end.
Old 27th November 2020, 07:11 AM   #15
wiseoldtech is offline wiseoldtech  United States
wiseoldtech's Avatar
I'd simply replace the amp chips, and as Mooly said, load a 100 ohm resistor to each, dim-bulb it, and if everything checks out, call it a day.
Bohemian Guru sagacious, professional.
Old 27th November 2020, 07:30 AM   #16
Yep all up and running and I have to say it sounds pretty rich and balanced. I was a bit sceptical about the simplicity of this amp but sound is good.
  Reply to this post
Tda 1514a help pleaseHide this!Advertise here!
Thread Tools
tda 7293 and tda 7294 help sagarverma Chip Amps 85 22nd March 2013 09:15 PM
tda 1514a 220 pf capacitor asbn369 Chip Amps 1 19th August 2010 06:42 AM
Tda 1305 & Tda 1302 hifive Digital Source 1 10th April 2006 10:04 AM
TDA 1514A not holding its own RIC Chip Amps 23 30th September 2004 05:39 AM
could John Audio re-desigh the Trace elliot TDA 1514A layout RIC Chip Amps 1 27th December 2003 05:39 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
