Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Chip Amps Amplifiers based on integrated circuits |
Thread Tools |
#21 |
The yellow/blue stay joined and become the 'zero' or 0V ground connection as shown here (generic circuit off the web).
The red and green go to the rectifier and it doesn't matter which one goes where.
Installing and using LTspice IV. From beginner to advanced. |
#22 |
Okay, thank you. Now, back to my original question: What do I connect to the connectors that come from pin 10 and pin 1 please?
#23 |
Answer can be found in post 7. Pins 9 and 10 are Inputs. 1 and 5 are power +. 4 is power -.
Regards Mark. |
#24 |
Yes, thank you I know that. I am referring to my original post and the photograph where I have said that I am stuck. I need to know where to physically connect from the connectors soldered to my board in the places that are ringed on the photo to where they should be connected to next.
#25 |
I think we need a bit more info from yourself here
![]() Lets begin with the power supply and transformer. Is that wired up correctly now to the rectifier and reservoir caps?
#26 |
#27 |
It still all sounds a bit of a mystery tbh.
Pin 1 of the LM3886 and pin 5 of the chip should be joined and these then go to the positive rail which will be the plus end of one of those large caps. So looking at your picture the + end of the cap furthest from us would be that point. I can't understand why you would have pin 1 coming out to a connector. Pin 4 of the chip should go to the negative rail and that looks like it would be the negative pin of the cap nearest to us. Pin 10 is the non inverting input of the chip and is where the audio is applied but it should not just be a connection direct to the pin. This input should be tied to ground (the 0V point) via a resistor, typically 22k. PRR posted a diagram in post #7 which I think is from the site you linked to. The configuration of the chip should be as in that diagram. You can see pin 10 goes to a volume control in that image. A good way to figure things out is to look at each pin of the chip in turn and confirm it goes where it should.
#28 |
Okay I will have a close look at all of it and re-check what I’ve done. Thanks so much again for your help.
#29 |
Working from pictures is never easy but if you get stuck then just ask
![]() One thing I would say is that you must use a 'DBT' or dim bulb tester with this project. It could save you from expensive mistakes as you first power it all up. It's vital... and use a low wattage bulb if you can such as a 60 watt or lower (filament type only)
#30 |
I am using a DBT at all times, don't worry
![]() ![]() I hope you can see what I've done from this. I know it's not a schematic, but it's all I can do ![]() |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Novice dreams and novice questions | tatagatha | Chip Amps | 34 | 2nd October 2016 09:23 PM |
Complete novice | Rev G | Introductions | 2 | 29th September 2015 06:27 PM |
Complete Novice Needs Help | richluvsound | Pass Labs | 340 | 9th May 2015 10:42 PM |
Complete tube amp novice got a few questions!! | Boscoe | Tubes / Valves | 22 | 22nd August 2010 05:52 PM |
reg psu q - stupid (novice!) | lazyfly | Chip Amps | 14 | 10th September 2004 02:44 PM |
New To Site? | Need Help? |
