Guitar is one channel. You have to "Y" the one signal to the two channels.
Oh I see, how do I "Y" it?
......you can build in a mono switch
Can you explain a bit how to build a mono switch for the circuit I have? The picture is at my previous reply.
Assuming your guitar has a 1/4" mono phone jack, this cable, or a similar one, should work:
Amazon.com: TISINO 1/4 inch TS Mono to 1/8 inch(3.5mm) TRS Stereo Interconnect Cable(Mono to Stereo)- 3 feet: Industrial & Scientific
.......do you use a guitar preamp?
My guitar has a preamp built-in. In this case I would assume the preamp output is mono.
Thanks for your suggestion, it will be in my list.
........a little on-off switch connected with these two points ("mono switch")
gives you mono or stereo operation.
I made the switch and the amp buzzes loud. I extend wire out of the 2 connections.
- Chip Amps
- TDA7297 only working on one channel.
