Electric bass headphone amp with PAM8403
Old 2nd April 2020, 03:39 AM   #11
PRR is offline PRR  United States
PRR's Avatar
There *really* are better chips for headphone amps. You do not need class D for a milli-Watt job. You do NOT want bridge-mode output for common 3-wire headphones.
Old 2nd April 2020, 04:34 AM   #12
cbdb is offline cbdb  Canada
Probably doesnt have a high enough input impedance for a passive guitar. And its 5 watts into 4 ohms it will be a lot less into high impedance headphones.
Old 2nd April 2020, 07:00 AM   #13
FauxFrench is offline FauxFrench  France
You are right that it will be much less than 5W in high impedance headphones.
Without knowing much about headphones, 200mW in 32 Ohm should be quite decent. 200mW in 32 Ohm requires a voltage of 2.5Vrms which is possible because the PAM8403 has a BTL-coupled output.
Old 2nd April 2020, 07:10 AM   #14
I fully agree it is not an obvious or rational choice. The initial question from the OP was if it "would work" and my impression is that it is possible to make it work.
Sometimes you have such items lying around and like experimenting with their use. As a commercial product it is no good.
Old 2nd April 2020, 09:15 AM   #15
francescoboc is offline francescoboc  Italy
Yes, that's exactly my situation. I found this little thing in a drawer (I don't even remember how/when I got it), and I thought I might try to build an headphone amp for my bass, since I don't have one (and since I am quarantined...). I could, of course, buy a better chip, but I think it would be fun to see what can come up with this one.
Unfortunately, I cannot really start right now, because I realised I am missing other pieces (the 470uF cap, and the female audio jack for connecting the earphones)... So for the moment, I am just gathering information.
For the headphones, I will be using Sennheiser HD 205, which have 32 Ohm impendance.
Could you guys/girls please elaborate on this statements? I don't really understand what you are talking about...
Old 2nd April 2020, 09:27 AM   #16
chermann is offline chermann  Austria
Hi Francesco.
i try point 2 and 3:
electrical power is the product of power P = Voltage U * current I => P=U*I
if you but in ohms law , U=I*R then you will get P= U^2/R or P= I^2 *R.
so the resistor = speakers impedance = headphones impedance , yours 32ohm at the same level of output voltage limit the current and therefore the electrical power. but as FF wrote enough for headphones.
P = U^2/ R = (2,5Vrms ^2 )/ 32R = 0,195Watt or 195mWatt
if you would use a 16ohm headphone- less resistance more current
P = U^2/ R = (2,5Vrms ^2 )/ 16R = 0,390Watt or 390mWatt
for point 1 by PRR i am not sure what he mean....but he will give us an answer
chris
Old 2nd April 2020, 05:31 PM   #17
32 ohm hps should be loud enough, I was worried they where over 100 ohms. The 2 problems I can think of are: guitars usualy need high impedance inputs, 1 meg, and most bass amps have a lot of bass eq.
Electric bass headphone amp with PAM8403Hide this!Advertise here!
Self contained electric acoustic u-bass luigiman Instruments and Amps 65 26th June 2020 07:27 PM
Match Electric guitar output to PAM8403 Amp input mnesarco Chip Amps 4 14th June 2013 06:32 AM
Best tube combo for an electric bass.. Alexontherocks Instruments and Amps 6 8th October 2011 12:56 AM
any electric bass players? im building a bass guitar cab KOA Instruments and Amps 27 30th April 2007 03:49 PM
L-T subwoofer for electric bass amp? BAM Subwoofers 2 19th May 2003 09:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
