Can the STK459 handle a 2.6v input?
Old 13th March 2020, 02:43 AM   #11
Mark Tillotson is offline Mark Tillotson
If you use a bipolar opamp in that tone section then the base pot may give issues as you are passing the opamp bias current through its wiper.
Old 14th March 2020, 02:23 AM   #12
sgrossklass is offline sgrossklass  Germany
That is correct. Another FET input part would be a better match. (If TL072 is too wimpy, maybe OPA1642?)
Besides, I would use this relatively noisy tone circuit at line level only, with the volume pot following. I would use maybe a 20k volume pot and another opamp to provide anywhere from unity gain to +6 dB.
Actually the 5532 should work well for that position then, levels at this point are low (so common-mode distortion should be a non-issue) and you would have no problem getting feedback network impedance low enough, e.g. 1k/1k, as the part is a good load driver. (It would need an input capacitor of maybe 10 F and a ca. 47 kOhm bias resistor to ground though; I would also add 220-330 ohms in series with the noninverting input for stability reasons.)
I found another version of the sample circuit, the disappearing resistor is a 330 ohm there, so Av = 40 dB. Output noise is given as 1.2 mV, which is rather unacceptably high in my book. (The STK4xxx2II series has the same spec, it's a maximum there. Not very meaningful.) I did not find a spec for minimum stable gain, but knowing these old circuits, it may not be lower than 30-34 dB.
FWIW, I turned up an amplifier using the larger STK-461 (2x20 W), the Akai AM-U01, with schematic and specs. It uses almost exactly the application circuit and is given with an SNR spec of 90 dB. That would be ca. 400 V of output noise, rather more in line with a (run of the mill) 1980 vintage hi-fi amplifier and indicating ca. 4 V worth of effective input noise.
You know what? I would want to use a bit of a trick to bring gain on the STK down:
Can the STK459 handle a 2.6v input?-ultrasonicboost-1-png
I think we can live with a boost of +0.2 dB at 10 kHz and +0.7 dB at 20 kHz.
Then the preceding opamp (5532) could be set up for a voltage gain of ca. +6.6 dB (for example, 1.2k + 1k) to make up for the lost gain. Most of it, anyway - a 15 wpc amp does not really need more than 37 dB of gain even for a 150 mV input sensitivity.
All of this would drop output noise from ca. 400 V to 150 V, far more in line with a decent amplifier. (The bottleneck is in fact still the STK...)
Note: The 6 MHz GBW assumed in simulation for the amplifier model is likely to be overly conservative. It is likely to be anywhere from 10 to 100 MHz in reality, possibly 20-30. An LM1875 (typical gain +26 dB) is spec'd with 5.5 MHz already.
Can the STK459 handle a 2.6v input?Hide this!Advertise here!
EXDF mode and how ak449X DAC's interpolator handle a hi res input? laserscrape Digital Line Level 0 14th October 2019 08:54 AM
PCB Routing Advice Needed: How to Handle Input/GND butizzle Construction Tips 7 6th April 2015 04:03 AM
STK459 replacement Lumbermatt Chip Amps 21 29th January 2015 08:07 PM
How to use STK459 in bridge mode tridibesh Solid State 0 4th June 2005 07:40 AM
Stk459 / Stk463 nbcd Chip Amps 4 15th September 2004 11:51 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
