Chip-amps suited as power stage in a composite amplifier, LM1875/TDA2050 excluded.
Old Today, 02:39 PM   #91
Turbowatch2 is offline Turbowatch2  Germany
@chermann
Chris, you mentioned that the board does something strange.
Before my generator died, I saw something similar to page 9 figure 6 here:
http://www.ti.com/lit/ds/symlink/lm3886.pdf
So your what you call "strange" may be just the advanced protection kicking in.
So it might not be a fault, but a feature! So in my logic, any measure to "correct" this clipping behavior will be useless.
Old Today, 03:58 PM   #92
FauxFrench is offline FauxFrench  France
Originally Posted by Turbowatch2 View Post
@chermann
The strange phenomenom is probably the SPiKe interference in figure 5.
I had it also and as it is intended, Chris can't "iron it out".
Good to see a cheap board that works quite well and can be used for teaching of young DIYers and experiments for experienced DIYers.
Old Today, 04:57 PM   #93
chermann is online now chermann  Austria
Hi Turbo
Hi FF
as you look back to my pic (pic 6 at post 87) where i wrote its strange its just 16,1V rms into 8R = 2Amps ...and then i should get SpiKE???? no .....its near the max voltage swing because of the supply is +/- 25V. figure 15
Chip-amps suited as power stage in a composite amplifier, LM1875/TDA2050 excluded.Hide this!Advertise here!
LM1875 in parallel configuration and used in a composite amplifier. FauxFrench Chip Amps 550 17th March 2020 04:09 PM
TDA2050 vs. LM1875 for my gainclone lineup Chip Amps 11 1st May 2018 06:01 PM
Stereo LM1875 / TDA2050 PCB with Power Supply kuldeepsingh Chip Amps 35 27th May 2012 11:29 AM
Power output test LM1875, TDA2050, TDA2040 johnr66 Chip Amps 5 6th May 2011 06:28 PM
LM1875, TDA2050 on 2 Ohms johnr66 Chip Amps 6 18th February 2010 01:55 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
