LM1875 in parallel configuration and used in a composite amplifier.
Old 20th February 2020, 12:40 PM   #491
FauxFrench is online now FauxFrench  France
I finally implemented 100pF (foil) and 6K2 in series as feed-back for the OP-AMP in my composite amplifier. Good stability but an important over-shoot at the output of the OP-AMP with a fast square-wave at the input due to the OP-AMP being faster than the power stage. For frequencies in the audio-band it is not a problem. I will try to clamp the output amplitude of the OP-AMP.
I measured an output off-set of 10mV (0.5mV at the OP-AMP input) and noticed that the "pop" at start-up and shut-down now appeared. It is most likely due to OP-AMP reaching its operational equilibrium slower that the power stage. Still no hiss or hum.
Tested the amplifier on the speakers with different kind of music inclusive Turtles "Happy together". I found no artefacts and the bass is powerful. With Turtles, the choir (and some trumpets I believe) was still transparent.
I calculated the loop-gain at 1KHz to around 120. That should bring the overall THD to the level 0.000X% as measured by palstanturhin. Exactly how much, my ears cannot tell and my present sound-card does not allow tests below 0.00X%.
I will experiment with OP-AMP output clamping and my better regulated power supply before constructing the other phase-inverted half.
Old 20th February 2020, 01:18 PM   #492
chermann is offline chermann  Austria
yes.yes.yes....very good FF
Old 20th February 2020, 10:37 PM   #493
I got my regulated symmetrical power supply on it tonight. Very low dynamic output impedance. A quick test with +/-24V supply and 4 Ohm indicates much less "woolly" saturation tops than with my unregulated supply. I will try to take photos tomorrow.
Old Yesterday, 02:14 PM   #494
With my low-impedance regulated power supply adjusted to +/-22Vdc and with 1KHz at the input, I got the following results:
Pict.1: Clipping at 36Vpp in 2.7 Ohm. Vertical part due to recovery of OP-AMP output.
Pict.2: Square-wave at 15Vpp in 2.7 Ohm. Spikes at start difficult to see.
With my regulated power supply, the clipped flat tops are much less "woolly" than with the unregulated power supply.
I will try to remove the SQW start spikes by clamping the OP-AMP output.
LM1875 in parallel configuration and used in a composite amplifier.Hide this!Advertise here!
Composite LM1875 MiniAmp and HeadphoneAmp bkercso Chip Amps 3 20th November 2019 12:49 AM
Composite LM1875 stability issues Glkjh Chip Amps 5 8th June 2019 03:32 PM
Speaker Parallel Configuration anoopkrajan Multi-Way 3 10th February 2018 02:10 PM
Need help with Triple Parallel LM1875 dynamics amplifier. danielwritesbac Chip Amps 146 9th July 2014 06:27 PM
Honeycomb composite panel enclosure, dual opposed configuration rhapsodee Subwoofers 6 1st September 2010 04:26 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
